Results 1 to 16 of 16
Thread: flowmeter
    Active Member Two Rings desireroom's Avatar
    Feb 22 2016
    spain
    flowmeter
    Hi , I'm new here and I hope conteis with me for anything , I will try to help as much as possible .
    for now I need a little help with theme flowmeter .
    dark blue : intake air
    Light Blue : rpm
    Green: o2 sensor
    Flowmeter is K.O?
    Enviado desde mi SM-N920C mediante Tapatalk
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    What year and engine do you have in the car?
    That graph can vary depending on load while the rpm stays the same. Think about using the cruise control going up a hill. The rpm's stay the same, but the engine will need to work hard and consume more air.
    Do you have any other symptoms?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 22 2016
    spain
    AEB is a 1.8t 1996 .
    the graph is made of lina straight and smooth, without ups and downs.
    other symptoms :
    if I gunned the engine ceases to push and jerks*
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    you said dark blue is airflow, and it looks a lot of up and down to me
    2000 S4- Working?
    Feb 22 2016
    spain
    That's what I think.
    should make a log of 1000rpm to 4000rpm in 4th speed?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by desireroom View Post
    you should unplug the airflow sensor and see if the car works better
    2000 S4- Working?
    Feb 22 2016
    spain
    but my car does not have "map"
    I can also do this test ?
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    What redline was saying is that instead of seeing a nice waveform from the MAF (intake air) its pretty jagged and messed up, indicating possibly a failing MAF (flowmeter). By unplugging the MAF the car defaults to set values. If the MAF is going bad then unplugging it can make the car run better (although still pretty bad).
    Even though the AEB doesn't have a MAP sensor this still works.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Feb 22 2016
    spain
    I test it tomorrow and I will tell me how it goes . many thanks
    Feb 22 2016
    spain
    unplugged flowmeter is a disaster pulls no acceleration .... much worse , and aprobechado to cleanse and take another walk and I get the following error:
    throttle position sensor ( G69 ) implausible signal.
    but I changed the intake throttle and keeps coming .... that ruling is not where to look and blocked me ... : (
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    What exactly did you unplug? Fotografias, por favor
    2000 S4- Working?
    Feb 22 2016
    spain
    I unplugged flowmeter and was very wrong , clean and remounted . I went after the failure ( G69 )
    photo is google . but that the flow meter , which unplug .
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Got it.
    So you tried another throttle?
    Do you have vag com? And have you performed a throttle body adaption?
    2000 S4- Working?
    Feb 22 2016
    spain
    I have 3 throttle valves and 3 fail me just try . if I did the basic adjustment VAGCOM ... can not be
    Feb 22 2016
    spain
    problem solved, the throttle cable was very tense and to fail the intake throttle. Thank you all for helping me. I'll be by this forum to help other members as well. tomorrow I'll upload some pictures of my car so that it veais
