Results 1 to 40 of 63
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    8,925 Miles and guess who needs 4 tires :D
    Soooo Iwent to get the tires rotated and balanced on Saturday and got turned away suggesting I would need tires in about a thousand miles. Went out looked at the tires and sure enough they are about to be on the wear bars, all four tires are pretty even with no alignment wear. Is this common for the stock Continentals? No I have not done any track days either.
    Also I see a lot of you guys (searching and random posts that have popped up) rocking the Michelin Pilot Super sports [i think]. I have always enjoyed Toyo Tires, anyone got an opinion against those?
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Established Member Two Rings paulo6's Avatar
    Apr 17 2014
    Ford Explorer, Honda Element. retired a Cobb Tuned E60 535xi for the S4
    Ann Arbor, MI
    YES! I assume u have 19s summer Contis right? I changed mine at 14k and really should have done so many miles earlier. Paid $1000 for PSS. Arguing with dealer, Audi or continental was useless ... For me at least.
    Should find more info around here too
    Paul. S4 Prem+, Grey, Optic Black, Sport Diff, Nav+, BO
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by paulo6 View Post
    correct. Great so I might as well just bite the bullet and hand over the debit card.
    Established Member Two Rings TheLetterJay's Avatar
    Sep 26 2015
    ATL | NYC
    Quote Originally Posted by theswoleguy View Post
    Unfortunately, that is about the normal wear for these tires (mine were finished in about 11k) which sucks.
    I haven't heard anything negative about the Super Sports if you get mainly warm weather in your area. A quick search around the forums should prove helpful for general reviews.
    Sent from my XT1575 using Tapatalk
    2018
    034 Mounts, Inserts, Rear Sway, Front Strut Brace | ECS Intake, FMIC | ABT H.A.S. | Forgestar
    Gone
    2014 S-Tronic
    Eurocode Alu Kreuz | CR-15 | 034Motorsport Transmission Mount, Strut Mounts, Rear Subframe Inserts | Solo-Werks | ECS Luft-Technik Intake, Rear Diff Mount Inserts
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by TheLetterJay View Post
    same location as you, well close enough as I am in Smyrna it's only cold here like 5 days out of the year haha.
    Sep 26 2015
    ATL | NYC
    I wanted to pick up a set of PSS for my car, but chickened out and switched to the A/S3's due to the longer tread life, lol.
    2018
    Gone
    2014 S-Tronic
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Seems pretty common for those tires. My car came with Pirelli summers (18" wheels); I pulled them off at almost 8k miles to swap out winters and don't think I will get more than 16k out of them, which seems OK.
    I will be replacing them with PSSs.
    Nov 23 2014
    North Carolina
    yep, down to the wear bars on 2 and steel belt in the center of 1 after 12k. really sad to see them go so fast. have winters on now, but will be going to PSS once it warms up.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Veteran Member Three Rings Reckon's Avatar
    Jul 16 2015
    St. Petersburg, FL
    I had mine last to about 15k miles, but I do mostly straight line driving. I went with all seasons for my current area but will probably go back to summer tires as I am moving to FL shortly.
    2014 Estoril Blue Audi SQ5 Prestige
    2017 Ebony Black Jaguar F-Pace Prestige
    Dec 19 2014
    Virginia
    My conti's lasted 6k of hard driving lol
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by Dudemans4 View Post
    Lmao and this is why you and I can't hangout in person. Testing skid pad g-force loading on the way to Kroger
    Sent from my SM-G928V using Tapatalk
    Jul 16 2012
    Mid-Atlantic
    Mine lasted 7200 miles (replaced at 4/32nd).
    Just had a state inspection after 4000 miles on the PSS'. I'd only lost 1/32nd on the front and the rears are still on the full 10/32nd. Worth it!
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Jan 10 2014
    San Antonio TX
    It's well documented on this forum that the stock Contis are garbage. I changed mine out at 12K miles, but they were noisy at about 8K miles.
    I'm running Michelin Pilot Super Sports now and they are better in every way.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Yea unfortunately these factory summer tires are absolutely shitty. they grip quite well but you can see them wear down as you drive for one day. Hopefully they change the summer tires to something better. But im sure that these were the cheapest option for them when they built the car. Im at 11K and im at 3-4/32 im getting close
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    Is it pretty common for tires in general to not last that long on the B8's? My 12 STI ate through tires also even with regular rotations.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Shit that's good...my Mickey Thompson dr's last about 3,000 lol
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 19 2014
    Virginia
    Ha-ha all my car friends say the same thing .
    2010 s4
    Gone:
    Active Member Two Rings Bmil128's Avatar
    Jun 26 2014
    I went the AS/3 route hoping for longer tread wear as well, I have about 17k on them, down to 3/32-4/32 on all four of them. They are much better than the Contis but if I had known they wouldn't make it past 20k I would have looked harder for the Super Sports.
    Apr 04 2012
    MSP
    Keep an eye on your tires, tread and pressure... same as oil levels and other fluids. You should know what condition your tires are in before a shop tells you... Just a word of advice
    I'm in need of new summer tires too - I'm going with PSS this time round... expensive but well worth it.
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by MrFunk View Post
    i do on a regular bases but never had a car burn through tires in 9k miles other than on my gti when I tracked it. Now I know this car likes to eat tires the same mistake won't be made again.
    Active Member One Ring Caliwild's Avatar
    Dec 31 2014
    Los Angeles, CA
    My Contis were done by 14K miles. Switched to Bridgestone Potenzas and love 'em. Hope they last a bit longer...
    "Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?" - George Carlin
    Dec 07 2014
    Mn
    My set just arrived last week. 250 a piece on tire rack.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    yeah my stock continental tires lasted about 10k . . . I'd love to get something different other than michelin pss simply because everyone seems to have those tires.. i'd be interested in hearing some other good alternatives to the pss just for the sake of having some alternatives to the pss.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    For as crappy as these tires are, you would at least expect to get longer treadlife out of them. Unfortunately, it seems that they don't have any redeeming qualities. And they're expensive, too!!
    Active Member Two Rings charlesml3's Avatar
    Dec 05 2015
    Wake Forest, NC
    Those of you that have changed to Pilot Super Sports:
    Is the tire noise reduced? I know I'm not going to get a lot of miles out of the stock Continentals and the PSS seems to be the way to go.
    Has anyone tried going to an H rated tire for longer treadlife?
    -Charles
    2015 S4 Prestige. Sepang Blue with Nogoro Blue interior.
    Mar 12 2004
    socal
    I wish my crappy stock continentals were already gone! 11k miles and still life left :(
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    Quote Originally Posted by charlesml3 View Post
    -Charles
    Yes, tire noise is definitely reduced... but I had stock Dunlops. So I don't know how the Contis are in comparison. Although the PSS's get relatively long tread life (compared to other "summer" tires), they still don't last as long as some of the better all-seasons. My first set lasted 30K (right at the warranty mark). I'm 12K on my second set, but this set still looks almost new. *shrug*
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Jul 16 2012
    Mid-Atlantic
    -Charles
    Why go to an H-rated tire for an S4? Seems like it wouldn't be enough tire - also, correct me if I'm wrong, but I think that if you don't have the minimum factory speed rating on the car, you could have insurance issues in the event of an accident.
    Max Performance for the summer (whether it be the preferred summer-only, or a good set of all-seasons) and a dedicated winter tire (if you get the summers) is the way to go!
    Jan 29 2016
    wow I'm at 19500 and i still have tons of life on them. i think i can go till 30k lol i really do baby the heck out of it tho
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by Works2shoot View Post
    Correct and any tire shop worth their salt won't sell/install a tire speed rated lower than rated from factory as it would open them up for lawsuits as well.
    Apr 04 2012
    MSP
    Quote Originally Posted by brianc21 View Post
    Whoop!
    I'm in need of 255/30-20 and I think those are running 320 a pop!... I'm waiting for their $70 gift card deal to order which they run every few months or so... Not that $70 makes a big difference but since I don't need the tires until the spring I might as well wait for that deal again...
    Mar 28 2013
    Orange County, CA
    I, like a few others here went with A/S 3's thinking the higher tread wear warranty would be a worthy trade off. After wearing them out in 20k miles though, I know now they are not. Thankfully Michelin is great about their warranty and I got over a 50% discount on PSS's, which are worthy of their great reviews. Car feels better and more planted, smoother and quieter as well. No issues in the rain, and I never deal with snow although The A/S 3's didn't rate well in that dept either. I'm on track to wear these at about the same rate, but that's fine since the warranty will continue to effectively reduce their cost, making them an even better value.
    Mar 25 2015
    Calgary
    Threads like this make me realize there is not point in rotating the stock conti's. If Im only going to get ~12k miles on them, I might as well keep them quiet.
    Nov 23 2014
    North Carolina
    you might get another 1000 with a rotation :)
    2019 X3 M40i - Sold
    Dec 05 2015
    Wake Forest, NC
    You are wrong. The insurance company is there to cover you for an accident. They are not going to get into it with you over the speed rating of a tire. Same as they're not going to get into it with you if your tires are worn, even if that could have been a contributing cause of an accident.
    And to answer your question: Why go with an H-rated tire? 1) They're much quieter. 2) They'll last a lot longer. 3) I don't need a Z-rated tire to drive to and from work. 4) They're usually less expensive than the Z-rated model in the same size.
    Dec 05 2015
    Wake Forest, NC
    Nonsense. The car isn't rated for the tire. That's not how it works. The tire is rated for the car AND how/where it's being driven.
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Get some RE71r's... slap 'em on another set of wheels and get to the track!
    This is how you have some real fun burning up rubber.... I'm gonna get one more day out of these at Road Atlanta. Come on out!
    Dec 07 2012
    Atlanta, GA
    Yes the tire is rated for the car but you are incorrect. I turned wrenches for years through college. No shop should install a tire with a speed rating lower than rated for from factory. Thus is why a vw gti has an h rated tire and limited to 132 to not exceed tire rating.
    If you someone put an S or T rated tire and you went out and got into an accident and it was deemed tires were at fault, depending the outcome, you and the shop could be held liable for defective/incorrect equipment no different than if you had an accident due to bald tires.
    Same situation applies if you put a load rated tire that is less than what the vehicle is rated too example a P tire instead of lt with load range above sea with load range above C or D
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Replaced my stock Conti's last month before 12,000 miles on the odo. They were down to wear bars. Glad to be rid of those noisy tires! I went with the S-04's instead and loving them so far, except for slight rubbing on rear right. Size is same as stock, but the tread patch of the Bridgestones are significantly wider than the Conti's even though same size. Love the more flush/square look!
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    [QUOTE=charlesml3;11421932]You are wrong. The insurance company is there to cover you for an accident. They are not going to get into it with you over the speed rating of a tire. Same as they're not going to get into it with you if your tires are worn, even if that could have been a contributing cause of an accident.
    My neighbor just rolled his car in snowy weather getting onto an off ramp. Single vehicle accident, got a ticket for not enough tread on his snow tires
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
