its been a while since ive been on here and wanted to share my recent find and ask a question to anyone with some insight. I bought an 01.5 6 speed avant with 260k on the clock from its second owner, its been properly maintained and is all original except for a giac chip which is throwing the epl light, euro decklid and wagner s4 intercoolers and apr dv's.
I dont drive it every day as its my snow car. The last time i did i came home on a tow truck. i literally parked the car, came back out of the store and it wouldnt start. after getting it home I decided to put in a new fuel pump, filter and pressure regulator, spark plugs, coil packs, icm's and a crank position sensor (g28) i have also switched around cam position sensors and verified the wires for g40, g163 and g28. I have verified that the wires from the ecu to the icm's and from the icm's to the coil packs are ok as well. I have a stock h box and m box and have tried to start the car with both and i still have no spark and yes all the the fuses and furl pump relay are ok.
So i'm really stumped, i have a few 2.7's in my life and a ton of parts but am now at the end if my rope and looking for help. I will be re-timing the engine tomorrow as i believe one of the heads is off a tooth but that has never created a no start so yea... ive searched the threads and no bright ideas have come up, followed the bentley manual and used common sense, now im turning to my fellow b5'ers in hopes of learning why the car wont give me spark.
thanks in advance for reading, here's a few pics as threads are boring without some sort of car porn ;)
