Results 1 to 7 of 7
    Oct 26 2015
    Norman/OK
    2016 SQ5 oil change question
    So we got the firs tone done at the dealer, when talking to them I got a list of the service work for the next 75k miles or so. I was asking them about some stuff on the 15k as I will do it myself and the dealer said while I can do it they will have to turn the service reminder off at a cost of $60...!!!
    Other than that sticker shock I was planning on doing the oil change old school style, jack the SQ5 up and remove the drain plug and drain the oil. Put plug back in and fill with oil. Service writer and tech said that is not how they change the oil, they suck it out as they said it is easy to strip the oil drain plug.
    Anyone on here change their own oil on the SQ5, is sucking the oil out the dipstick tube the preferred way?
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    you can suck it out, i still prefer to drain from underneath.
    B6 S4 Cab - Sold
    B7 S4 - Sold, (sadly sold, this was my favorite)
    C6 A6 3.0T - Sold
    B8 S4 - Sold
    2015 SQ5 - Sold
    C7 A6 3.0T - Sold
    2016 SQ5 - Sold
    C7 S6 - Sold
    B9 A5 Sportback - Sold
    C7.5 S6 - Current
    Mar 21 2015
    https://www.audiusa.com/content/dam/...16_updated.pdf
    My dealer changes the oil in the S and RS models from the drain plug. Get a Ross Tech cable to do your reminder and tweak a bunch of cool shit. You can also use it to trouble shoot and clear codes as well as a bunch of other crap.
    Oct 26 2015
    Norman/OK
    ok, so you can drain from underneath as normal like most domestic vehicles. That is good to know, I have the Carista app as a beta user so I should be able to reset the service reminder.
    Jun 20 2014
    Ontario/Canada
    Quote Originally Posted by TJay74 View Post
    ....... they suck it out as they said it is easy to strip the oil drain plug?
    LOL, this is the service rep and the tech saying this.
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Quote Originally Posted by Black3.2 View Post
    That's what she said...
    "Beep beeeep bloop boop" - R2D2
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    I'm very old school as well and will be changing my oil every 5k.
    I drained my first one at 1k, then sucked it out the second time at 5k, then pulled the plug so I could see how effective it was. Not a drop of oil came out.
    My conclusion is sucking it out is cleaner, and easier.
    Both right imo but get a new drain plug washer each time.
    Also use the full synthetic 505 rated oils
    Steve
    '15 SQ Monsoon
