Results 1 to 18 of 18
    Sep 02 2008
    Boonies VA
    How to disconnect drivers sun visor
    I am trying to remove my A-pillars in order to fiberglass some speaker pods. Passenger side went smoothly, pillar out in about 5 minutes.
    I get to the drivers side and cannot figure out how the hell to unplug the sun visor. The passenger side the connector came down with the visor. Drivers the only connector I can see is up inside where the bracket screws to the roof. There is no way I can get even 1 finger in there to unplug it. Tried pulling on the wire a little and it's just tearing up the red insulation over the wires and I am afraid to pull any harder.
    Any tips? I really don't want to lay the fiberglass with the pillar in the car, but will if I can't get the damn visor removed.
    Thanks.
    White Wagon
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by naiku View Post
    Thanks.
    Passenger side and driver side visor have the same connector. I wouldn't pull hard, just see if you can get a pen or something up there and faniggle it to come down.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    The front where you removed the screw needs to move down and forward to come out. You might have to wiggle it a bit. Once out there is about an inch or inch and a half of wire slack. Once you have it out that inch and a half there is a little metal spring you have to press thru a small hole in the side of the plastic connector housing. the connector then slips apart.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    https://m.youtube.com/watch?v=0sZY8Qw5-dI
    Heres video by wolf auto
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by JDillon15 View Post
    Are there differences between home link and non home link? I see a connector through the hole that looks slightly larger. Will try a pen or hook of some kind.
    Quote Originally Posted by Older_not_Wiser View Post
    I have the visor down, there just appears no slack in the wire. The only thing I can think of is it is up there and some kind of bend/kink in the harness is preventing me getting it down any.
    Quote Originally Posted by p310b View Post
    Watched that video last night, no idea how he got the connector apart with it like that. Mine simply won't. Going to give it another try later and hope to get it down. Drives me crazy when simple shit like does not go smoothly.
    White Wagon
    Jan 15 2016
    Indonesia
    Good luck!
    Jul 11 2014
    Chicago, IL
    Not that I remember. I have home link on my car and IIRC, it's the same as the passenger side.
    Nov 15 2011
    Montreal | I sell in USD
    No they're different. If the driver visor has homelink its a larger connector.
    *****I sell in USD*****
    Mar 16 2012
    Lomita, California
    Yeah, sorry, no Homelink here. Above is mirror light only.
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by Axis View Post
    Good to know, it definitely looked like a slightly bigger connector up through the hole.
    White Wagon
    Nov 15 2011
    Taking it out is easy, putting it back can be a pita.
    If I may : moddifying this pillar could interfere with the curtain airbag.
    Sep 02 2008
    Boonies VA
    This is what I am also concerned about, if its this much of an annoyance to unplug, how much of a pain will it be to put it back again.
    Definitely understand where you are coming from, essentially I am not modifying the pillar itself. I am mounting a pair of small mid-range speakers up on the dash as close to the windshield as possible, but I want to mold the back of the pod the speakers sit in to the A-pillar so that it sits flush. The pillar itself will remain stock with no changes to it whatsoever. I am hoping to be able to make this back mold piece with the pillar out of the car, but I can possibly manage it with the pillar in the car if I am careful with the resin. For what I want to do, it may even be possible to make 2 molds off the passengers pillar (already removed from the car).
    White Wagon
    Nov 15 2011
    Its not that hard, just have to be patient. Just wiggle it a bit to pull it out, its probably stuck on something. You should be able to pul it out and unplug it outside of the headliner. Its puting it back where it wont block the sunvisor "J" tab thats tricky.
    And I would work with the resin outside of the car lol
    Sep 02 2008
    Boonies VA
    Success! Broke the clip on the connector but I think it will still hold fine when I put it back together. Had to push a small screwdriver into the hole, rotate the connector down enough to give me some slack and it popped right out.
    Now to lay some fiberglass and then have fun putting the pillars back in again.
    White Wagon
    Jul 11 2014
    Chicago, IL
    best of luck,
    Post some pictures!
    Sep 02 2008
    Boonies VA
    Not a whole lot to look at currently, but essentially I am hoping to build some kind of a pod to hold this:
    Neatly up on the dashboard, the only progress I have made so far is removing the pillars and taping them off:
    Hopefully I can get them looking at least halfway decent!! I had originally thought about recessing them down into the corners of the dash, but the amount of work required to remove the dash and then the simple fact of cutting holes in my dash did not really sit so well with me.
    White Wagon
    Feb 25 2011
    Seacoast NH
    wow cool. keep us posted.
    Sep 02 2008
    Boonies VA
    Made a little progress:
    Putting the visor back in was way easier than I expected. Getting the pillars back on was a pain though, lining those clips up was really annoying.
    White Wagon
