Results 1 to 40 of 40
    Oct 06 2015
    Atlanta
    B7 fwd automatic to quattro automatic swap....
    I have a 2008 audi a4 fwd automatic and I am look to get together a full parts list need to perform a quattro swap. I am sticking with the automatic trans because I have a full prosthetic leg on my right side... I have located a parts car a someone willing to ship me everything just want to make sure I don't miss anything. Thanks for the help in advance.
    Feb 25 2011
    Seacoast NH
    didnt Vizi do this?
    Veteran Member Three Rings saizero's Avatar
    Aug 11 2009
    Chicago
    Current AWE Boost Gauge : STaSIS catback : 034 HFC : ECS Snub Mount : Upgraded Piston DV : CTS Turbo Catch Can : ER FMIC : DTM Front/Rear Votex Side Skirts : Stasis/Ohlins SL Coilovers
    VAGCOM Owner
    AKA: vmSAi
    Oct 06 2015
    Atlanta
    It has been done manual swap just wondering what else is need as far as electronics.... like is tcm and just the engine harness is all that I need to add?
    Sent from my SM-G900V using Tapatalk
    Jun 27 2011
    But the FWD Automatic is a CVT and wont work with Quattro. I assume you're picking up a 09L 6-speed Tiptronic with that parts car right?
    You'll probably need a Tiptronic TCU and you'll need to recode your ECU to Quattro and Tiptronic. Don't think you'll need to modify/replace wiring, but I could be wrong...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 06 2015
    Atlanta
    Yes I'm picking up the trans as well
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    You'll need a new downpipe as well
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    And a new gas tank. you will lose 2 gallons of tank capacity.
    Jun 27 2011
    Quote Originally Posted by Brillo View Post
    Minor detail, haha.
    -CP
    2017 Q7 3.0t
    Sep 30 2009
    Indiana
    Indeed
    Active Member Two Rings hagerty47's Avatar
    Jan 08 2016
    Orange County, CA
    If you end up doing this could you make a build thread? I've been interested in this because I have more money into my 2008 then I can sell it for and made the mistake of not buying a Quattro.
    Would the Quattro trans bolt up just fine? I can't find much info on it. I've read through Vizis thread but I believe it was manual to manual correct?
    Oct 06 2015
    Atlanta
    Quote Originally Posted by hagerty47 View Post
    Yes I believe viz's was a manual to manual... I planed on doing a build thread as well
    Jan 08 2016
    Orange County, CA
    Awesome, keep us updated then man. I have a guy whose willing to trade me all the parts I need for the ones I take off and I'll pull the trigger and do it once I figure out more about the trans
    Oct 06 2015
    Atlanta
    Ok everyone I finally got my money back because the guy never shipped the parts.... them my car breaks down its going to be awhile before 8 can do the build.... just my luck get stuck dealing with shady mofos
    Oct 06 2015
    Atlanta
    *then
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Quote Originally Posted by shahk62 View Post
    Are they shaped differently ?
    Cannot fine a picture of downpipe for FWD for the life of me
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Oct 06 2015
    Atlanta
    Quote Originally Posted by DanKing View Post
    I believe the quattro one in longer for clearance purposes
    Dec 03 2013
    Malaysia
    I've just finished doing the swap from cvt to quattro automatic. You need all the parts from the quattro, including the engine. You also need the bracket from the quattro to hang propeller shaft in the car mid section. I'm stuck with the fuel gauge reading now, always full. Other than that, everything is good
    Oct 06 2015
    Atlanta
    Why the engine also? They should be the same motors?
    Jun 27 2011
    The cvt/manual have a different crankshaft than the Tiptronic.
    -CP
    2017 Q7 3.0t
    Dec 03 2013
    Malaysia
    True as what charles.waite mentioned
    Established Member Two Rings Forge04's Avatar
    Mar 20 2016
    2007 Audi A4 2.0T FWD 2009 Chevrolet Avalanche LTZ PAST: 1979 IH Scout II 1971 IH Scout II
    Middleton, ID
    Why has this never been said before in all the conversion threads? Facepalm.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by Pegleg View Post
    When you need a trans: http://www.audizine.com/forum/showth...ansmission-HYH
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Dec 03 2013
    Malaysia
    Engine crankshaft with CVT
    Dec 03 2013
    Malaysia
    Engine crankshaft with quattro transmission
    Oct 06 2015
    Atlanta
    Can't you just change out the crankshaft?
    Dec 03 2013
    Malaysia
    Theoritically you can, but i don't know what else involve in doing so
    Jun 27 2011
    B7 rwd automatic to quattro automatic swap....
    Of course you can. The only difference is the space for the needle bearing. The thing is, you have to pull the engine and completely disassemble it To remove the crankshaft. It's 10000x easier to get a different engine.
    Also there is no "Quattro" transmission. Do you mean Tiptronic?
    -CP
    2017 Q7 3.0t
    Dec 03 2013
    Malaysia
    Yes, tiptronic.
    Mar 20 2016
    Middleton, ID
    Any updates?
    2007 B7 A4 with 2.0T FWD
    Oct 24 2015
    Perth, WA
    I wonder if you could get a mating plate?
    My respray thread
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Okedokey View Post
    Wouldn't help. The tiptronic crank isn't machined to accept a pilot bearing which is needed to work with a manual transmission.
    -Adam
    Mar 20 2016
    Middleton, ID
    But that crank still mates up to the CVT... which doesn't have the pilot bearing...
    Mar 24 2013
    Oakdale, CT
    Manual and cvt cranks are the same and will also bolt to a tiptronic transmission. Tiptronic cranks will accept the manual flywheel but not the pilot bearing.
    -Adam
    Jun 27 2011
    This.
    -CP
    2017 Q7 3.0t
    Mar 20 2016
    Middleton, ID
    Okay, so let me see if I understand this:
    A Tiptronic engine will not allow a CVT/manual to bolt up?
    A CVT/manual engine will allow a Tiptronic transmission to bolt up?
    Because that's what I gathered from this recent activity, however, this post contradicts this:
    Quote Originally Posted by aams View Post
    So can there be a consensus? I ask because I have the CVT and would love to save up and go Quattro...
    Jun 27 2011
    Look up b5/6 Quattro swaps. It's the same deal.
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Forge04 View Post
    Your posted understanding is correct. The post you quoted is the bolded scenario. You don't need the engine, not sure why they said that.
    -Adam
    Mar 20 2016
    Middleton, ID
    But you can see the concern right?!
    Imagine spending all the time and effort to get the rear axle assembly, the gas tank, the driveshaft, and the electrical brain/wiring because at this point, lawl, who the hell knows exactly what one would need... only to find out that, sheeeeet, I need the whole engine too!
    And especially if aams just got done swapping... I've seen before where how it should work and how it actually works are two different things.
    Junior Member One Ring
    Apr 22 2018
    Oregon
    Bump👉
    As for cvt/ manual to tiptronic (fwd, yes same as old Passats) or FWD conversion you DON'T have to swap motor. Yes, cranks are different, but What I did, I did extensive research about bushings and find out that Dorman brand has bushings slightly oversized but it WILL work with crankshaft and torque converter after slightly "dremeling" around the cranshaft and sending down torque converter tip. Than I used starter plate from tiptronic and it's all fit like a charm. My question is, as I never dealt with vag before ( could not find anybody in Oregon to do so either) does it need to be coded after swaps regarding ECM, TCU (I'm assuming swapping TCUs it's given) or any other components? Sorry I'm a good mech but not a millennial 😁
