Originally Posted by
roadrunner_oz
Here you go, it is a DTUK, but uses the same sensors to plug into.
http://www.audizine.com/forum/showth...1#post10582243
No piggyback can compensate for fueling. Been discussed to death, so think what you want. The ECU is "blind" as to the actually boost be added so cannot adjust timing and fuel accordingly. If you are going to tune then do it properly with a flash.
What you linked me to is the DTUK unit on the race fuel settings of +7psi and it is showing similar behavior as the JB1 showed at those non recommended settings. Do you have any logs of any of these units at the +5psi settings? I'm still not sure how these +7psi logs of the JB1 and DTUK showing them both running lean would have you recommending away from the Neuspeed and to the JB1? I'm not saying the JB1 isnt a better solution but I dont see any data yet suggesting anything is better or worse yet. Have you?
roadrunner_oz
Sorry, yes, the JB1 can do so indirectly. The JB1 has an extra connector to a sensor on the intake manifold that relates to fueling.
The JB1 biases fuel pressure as a method of keeping short term fuel trims to a stock level. This means the ECU does not rely on a the lambda to see lean due to uncalculated airflow (because boost is tricked) in order to enrich the car. This makes a difference on DSG cars because the boost spike on the fast shitf causes lean spikes with most piggybacks.
This is not exactly the case. The JB1 biases the fuel rail. That is a much different thing than saying the ECU does not rely on lambda to calculate a proper afr. It still DOES do this with the JB1.. which is fine since the car runs in closed loop under load anyways.
What the JB1 supposedly adds is the biasing of the fuel rail. What this theoretically does is keep the fuel trims in check so that if you were running higher boost settings (the +7psi) settings that may require much higher fuel adaptations there will still be headroom in the adaptations because the computer is being fooled into thinking it is making less rail pressure than is really there. This is how things are "supposed" to work. As you could see from the JB1 +7psi logs it is not working that way. The car still will run lean and throw high EGTs apparently.
Either way, the lambda is still what is controlling the afr with ALL of these boxes.
OP:
Either way, the bottom line is to log your car. I havent seen ANY +5psi logs of any of these piggies yet for your cars and that would be what we need to see before making speculations about safety or running lean or not running lean. As long as you can stay within the factory allowable fuel adaptations it is certainly possible that the car will not run lean at all. In fact, Audi uses very conservative engine air/fuel enrichment and self protection strategies based on IAT, ECT, EGT, knock, etc feedbacks so it is theoretically possible that you could actually be running a RICHER air/fuel ratio compared to stock with a piggy back. I can show you logs on the S4 where this is exactly what happened. This is because the added boost will increase heat. Increased heat leads to increased IATs and knock and subsequently triggers the OEM enrichment calibration to kick in (sometimes earlier than it would have without the increased boost). Again, only logging is going to tease out what is really happening though. Id strongly recommend it.
Mike
