Here is the list of items that I have remaining from my part out. All of the major items not on the list have been sold, please do not inquire about items you do not see on the list.
I am looking to get rid of all this stuff as soon as possible to clear out the garage. All items are best offer!
To view an image of the item, click the link on the item name.
ENGINE PARTS
AC Low Pressure Line
Auxiliary Radiator (Driver) - SOLD
Auxiliary Radiator (Passenger) - SOLD
Auxiliary Radiator Shrouds
Auxiliary Water Pump - SOLD
Brake Dust Shields (Rear) - SOLD
Cam Sensors
Check Valve
Cluster - SOLD
Coolant Lines
Coolant Line (Driver)
Coolant Line (Passenger)
Downpipes - SOLD
Driveshaft (Center)
ECU - SOLD
ECU Box - SOLD
Electronic Control Module (ECM) - SOLD
EVAP Canister - SOLD
Fuel Injectors
Fuel Pump - SOLD
Fuel Rails
Knock Sensors
MAF Tube
Manifold Vacuum Solenoid (Black)
Manifold Vacuum Solenoid (Gray)
Master Cylinder Fluid Reservoir
Motor Mount - SOLD
Motor Mount (No Sensor) - SOLD
O2 Sensor (Front)
O2 Sensor (Driver Rear)
Oil Cap
Oil Filter Assembly
Power Steering Pump - SOLD
Power Steering Reservoir
Relays
Secondary Air Pump - SOLD
Throttle Body
Transmission (Auto) - SOLD
Waterpump Assembly - SOLD
Waterpump Coolant Pipe - SOLD
INTERIOR PARTS
ABS Module Holder
ABS Module Lines
Airbag (Passenger Dash)
Airbag Control Module
Alarm Siren
Amplifier (Non-Bose)
Antenna
Antenna Booster
Armrest Surround Trim - SOLD
Ashtray (Front)
Bose Audio System (Speakers, Amp, Subwoofer) - SOLD
Carpet - SOLD
Carpet Mats - SOLD
Center Console Cig Lighter
Center Console Lock Button
Center Console Upper Trim
Climate Control Unit - SOLD
Cluster Trim
Comfort Control Module Box
Dash - SOLD
Dash Air Vent Passenger
Dash Air Vent Driver - SOLD
Dash Air Vent (Center) - SOLD
Dash Side Covers
Door Card Arm Rest (Driver)
Door Sills - SOLD
Driver Kick Panel
Emergency Triangle and Holder - SOLD
Emergency Triangle Holder - SOLD
Hazard Switch
Headlight Range Control Module
Headlight Switch - SOLD
Headliner - SOLD
Headliner Deck
Headliner Rear Cover
Hood Release Lever - SOLD
Pillars (B- Lower)
Pillars (C)
Pillars (D)
Radio (Symphony II with code) - SOLD
Radio Cage - SOLD
Recaro Seats - Complete Set - Black / Alcantara - SOLD
SAT Radio Module - SOLD
Shifter Assembly (Auto)
Shifter Insert
Stalk (Cruise Control)
Stalk (Wiper)
Stalk (Turn Signal)
Steering Wheel Clockspring
Steering Wheel Control Module
Steering Wheel Surround
Sunroof Assembly - SOLD
Sunroof Motor
Telematics Control Module
Trunk Carpet
Trunk Grocery Hooks - SOLD
Trunk Jack - SOLD
Trunk Net Anchors
Trunk Spare Wheel Holder
Trunk Tool Kit
YAW Sensor
Welcome Home Module
Welcome Home Switch
Window Regulator (Pass Front) - SOLD
Window Motors - Driver / Pass Rears Only
EXTERIOR PARTS
B-Pillars
Belly Pan Splash Guards
Brake Booster
Bumper Fender Brackets (Front) - SOLD
Bumper Fender Brackets (Rear)
Charcoal Canister
Frame Rail Impact Absorbers
Gas Cap
Hood Latch (Lower)
Horns
Radiator Fan Control Module - SOLD
Sharkfin Antenna (Red)
Sharkfin Antenna (Silver) - - SOLD
Shifter Box
Shock Tower Assembly
Shock Tower Hats
Spare Wheel - SOLD
Steering Rack
Suspension Set - SOLD
Swaybar (Rear) - SOLD
Swaybar End-links (Front)
Tail Light (Driver) - SOLD
Tail Light (Passenger) - SOLD
Trunk Struts
Turn Signal Marker
Windshield Washer Fluid Reservoir Set
Wiper Motor
Wiper Transmission and Motor - SOLD
Windshield Cowl
