Results 1 to 17 of 17
    Veteran Member Three Rings Diamond Dog's Avatar
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Is it worth it to even change these Sway Bars?
    I have a 2011 S5 Coupe.
    Someone gave me their OEM RS5 sway bars. They are thicker than my S5 ones.
    If I was doing other work, (changing suspension parts), would you put these in or is it a waste? I see aftermarket sway bars for sale and am wondering what the difference between those and the RS5 ones would be. I would assume the RS5 ones are pretty nice, but I don't know that for sure.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    I went with the 034 Motorsport one. If you got the RS5 one free, maybe install and see if you feel a difference, but if I was buying new I would go aftermarket. It would be set up to be a bit more aggressive than probably even the RS5 one.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I would just skip putting the RS5 bar on unless you aren't even considering aftermarket sway bars. But the improvement will be marginal compared to the Eurocode/034 bars.
    The aftermarket bars are significantly stiffer than even the RS5 bar.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 19 2012
    Irvine, CA
    It wont be the big of a difference compare to Aftermarket Sway bars
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    I just went from stock RS5 swasy to EC sways and endlinks....huge difference. Virtually no body roll now.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    IIRC its a bit of a pain to change sways as you need to remove the exhaust to get to the rear sways. With that being said since you already have the RS5 ones and don't really plan on tracking your car, I would just stick with the RS5 sways and not worry about it.
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Unless I were tracking a car I really wouldn't want to go too stiff on sway bars, you lose more of the independent suspension comfort, the whole front and rear bounce more. However, free ones are ok to try!
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Quote Originally Posted by Sweep View Post
    Thanks for the advice. I actually have the stock s5 on a and the RS5 ones are in a box
    Sent from my iPad using Audizine mobile app
    Jan 18 2015
    Quote Originally Posted by GotRS? View Post
    Going to a stiffer sway bar isn't going to turn these cars into a live axle. I would argue that the stiffer stabar does almost nothing for ride comfort. I went from stock s5 suspension to Eurocode sways and my ride comfort is IMPROVED over stock. The trick is I also went with Bilstein coilovers and softened my damping as compared to stock. Dampers and springs are a pretty big knob for driver comfort. Suspensions should be pieced together with the entire system in mind. Just going with shorter springs to drop your car is a recipe for a harsher ride.
    My car also has zero bounce.
    Mar 11 2012
    Audi A5
    Ventura, CA
    I would put them on if you're working on something else down there. I just installed a stasis sway and did notice a SLIGHT difference. I probably wouldn't take everything apart just for that but like you mentioned if you're already doing suspension work and have the sways might as well toss em on.
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Mar 21 2015
    Keep in mind a good amount if not all are one time use bolts for the sways and endlinks. Some reuse with no problems but they are technically supposed to be used once.
    Senior Member Two Rings street sleeper's Avatar
    Jan 04 2015
    Pittsburgh, PA
    I was thinking of going with...
    H&R OE Sport springs
    H&R sway bars (front & rear)
    Thinks it's a waste? Anyone have this setup?
    2008 Audi S5 (6MT)
    Meteor Gray / Magma Red Leather / Carbon Inlays
    Euro Spec Headlights / 35% Tint / Satin Black Grille, Fogs, & Rear Valence
    AWE Track Exhaust / AWE Carbon Intake / Short Shifter / H&R Sway Bars
    H&R OE Springs / Brembo Brakes / BBS CH-R 20x10.5 / Michelin Pilot Super Sport XL 275/30ZR-20
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by street sleeper View Post
    Everything I've read about the oe sports parings says stay away. Seems to make the ride unbearably harsh. Although, would probably feel like you're cornering on rails. Lol.
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    I'm not sure what others are on about. Adding a stiffer rear bar is one of the best mod, and probably the best bang for buck.
    Our cars are nose heavy, and push like pigs. Unless you have the sport diff, a stiffer rear bars to help reduce the understeer. I would only go with a rear bar, not a front and rear bar, unless you like the current balance front to rear, which favors understeer. If you are looking to reduce body roll, I'd go with stiffer springs. I tend to like the stock springs.
    I had the H&R's on the rear, and it was an improvement over the OE's. I recently switched to the 034....which was much better! The 034's include billet ARB mounts, so not only is the bar stiffer, but the mount is stiffer, with less damping material. The best the car has felt, with greatly reduced understeer.
    Good luck.
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by ColtS5 View Post
    Good luck.
    No one is saying he shouldn't upgrade. We're just suggesting he skip the OEM RS5 bar and go straight to an aftermarket one, as the OEM bar is a marginal upgrade at best.
    Not sure on the exact numbers for the B8 bars, but as an example the 034 rear bar for the B7 was 100+% stiffer than the OEM RS4 bar. I assume it's similar with the RS5. None of the OEM bars are anywhere near as stiff as a good aftermarket bar.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by LINDW4LL View Post
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    I have a 2014 RS5 Cab. Trying to reduce the shimmy/cowl shake. I heard upgrading the sway with the combination of AK and coilovers will reduce this feel. Any feedback from anyone?
