Results 1 to 27 of 27
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    How often does your B&O radio cut out ?
    I know this is a known problem. My 2010 didn't have B&O. so I never had that issue. Only had my 2014 for a yr. But the radio on my 2011 has now cut out for the 3rd time, but twice in a week. It comes back after I park the car for a short time. Also. I noticed I could play music from my SD card when the radio would not play. Is there a fix for this? I'm afraid that one time it won't came back on.
    Aug 25 2015
    california
    Mine does the same thing. Maybe once a week. I just reset it.
    Grom
    Jul 16 2012
    Mid-Atlantic
    Sounds like an issue with a hot amplifier.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Odd, mine did it a few times early on but hasn't done it in a long time now, at least 3+ years. No idea what changed to make it stop.
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Only have two issues - some strange popping noise (very subtle) that handles randomly and sometimes audio level becomes unchangeable. The audio is more annoying than anything.
    Aug 25 2015
    california
    One of the most annoying things is the mmi doesn't save what SIRIUS station I was on. Say if I turn off the car it goes back to the preview channel maybe 50 percent of the time.
    Grom
    Apr 05 2012
    Earth
    I've never had this happen to me and I've had mine almost 4 years.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    I had it happen last fall and couldn't get it to reset and had to pull the manual out to remember the re-boot procedure.
    It hasn't occurred since.
    Dec 10 2012
    1983 Honda CB1000 Custom
    granville ohio
    3 times in 60,000 miles.
    2013 S4 Premium Plus, 6MT, Brilliant Black, Sport Diff, Red & Black Leather, B&O, APR Stage 1, AWE S-flo
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Never happened to me in the ~30,000km that I've owned the car (purchased at 72,000km, now at 100,500)
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    It hasn't happened to me. One time It didn't turn on when I started the car and I had to manual turn it on. But there is a guy that has updated firmware for the MMI maybe worth giving that a try if you are not updated to the latest and greatest.
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    MY cars B&O when I pass one spot on the highway gets stuck on and freezes, no matter what you do you cant turn it off. It is very frustrating, especially of you are using your gps and jamming out to loud music, It freezes, you cant turn the music down, and you get lost. The three buttons does not fix it, I have to pull over tun the car off open close the door and wait about 10 minutes.
    I have learned to prep when passing this spot, its far from my home, but I pass it now and then with work. ITs always the exact same spot on the parkway.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Last Friday my wife and I were going to head out for lunch. When I started my S4 (it was parked in our garage), I noticed that it was updating the stations list. After I pulled out of the garage, the update completed and my radio start playing; it was on a SiriusXM station. But I could not control the volume through the steering wheel or the knob on the console. About 15 minutes later, we hit a stop light and I turned the engine off, waited a few seconds, and restarted it. Still no volume control.
    When we got to the restaurant and I parallel parked the car, I got out to check its position (don't want to take the chance that someone might hit my front or back when trying to get in or out of a slot. So I got back in the car, started it up, and moved it a little and when I checked the volume control, it worked.
    During this time, when playing music from a flash card, the volume control worked fine.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Never done this...
    Apr 25 2010
    I-95
    Quote Originally Posted by schirm View Post
    MY cars B&O when I pass one spot on the highway gets stuck on and freezes, no matter what you do you cant turn it off....Its always the exact same spot on the parkway.
    Is there a cell tower there? When my car did it it was always in the same spot too, right near a big cell tower with some microwave dishes on it. At the time I speculated it had something to do with cell/microwave transmissions. But I still drive by the same spot all the time and it doesn't happen any more so who knows.
    Just the other day it did an update of the Sirius/XM stations and when it was done all my presets vanished. I was thinking maybe Sirius changed some channel numbers so the presets weren't valid any more but maybe it was something else, especially since some of the presets were broadcast stations.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    I have a 2015 with the B&O and I've had zero of the issues listed in this thread. Mine has been completely solid.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Scan the radio for codes.
    Stage 1 more than you RS3
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    That sounds super annoying. I would try updating the MMI firmware.
    Established Member Two Rings dean.mohr's Avatar
    May 11 2015
    '01 F150
    Toledo, Ohio
    Huh. Never heard of this! Though I agree, sounds like a hot amp but who knows. My 2012 w/B&O has never done anything like this and I listen to it loud non-stop.
    2012 S4 Prestige // Ice Silver Metallic w/Lunar Silver Interior // 6MT // Titanium Package // Chipwerke Pro // CTS Turbo Intake // AWE Track Exhaust (105k)
    2001 Ford F-150...with 265k and counting!
    I'll Always Remember You: 2013 Ford Fusion Titanium
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Got same issue as southern boy. My volume control on console and steering wheel would not work. Got message where the volume level normally appeared" currently unavailable" but this was only on the radio . On cd volume controls worked normally. After a few trips the volumes worked again. Occasionally I will see " currently unavailable" for a second when I flip between the radio and cd, but controls work. I rest midi after volume controls returned. I have appointment Friday. SA says they have seen problem before it is a module in the trunck
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Mine did it every few months for the first 3 years I had the car. Hasn't done it in the last 2 though...
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    I had issues with my stereo cutting out and crackling , especially when i hit a bump on the road. It ended up being a loose wiring harness that's connected to the amp.
    See the black harness with the purple thing connected to it? This is what was loose on my system. I ended up sticking a piece of sound deadening material to support the harness better so it doesn't come loose. I think my wiring might be a little stretched due to the aftermarket amp i have.
    So those with intermittent crackling noises, try this: Turn on stereo and wiggle the wiring harness. If you hear crackling noises when wiggling, you have a loose wiring harness.
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Oct 31 2010
    Lafayette, Colorado
    Mine used to, and a full reset of the MMI fixed it (three key reset)...
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by tsjordan View Post
    What is a full reset of the MMI? The 3 key reset? I am having problems with my B&O unit not having any bass. Took it to the dealer 2 weeks ago, they cleared codes and reset it. Worked fine for about 10 days, then stopped with bass again? It's in there today. Hopefully they don't try and charge me again, already paid $135 for "diagnostic" work the first time. I will link the other thread I posted in.
    http://www.audizine.com/forum/showth...-Olufsen-issue
    Nov 28 2015
    Montreal, QC
    never done this. 2013 B&O..
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Are you using HD radio? Mine did it for a couple of months when it was brand new (very annoying), but when I turned off HD radio, it never cut off again after that. So, I thought it was that HD radio is weak in my area. XM radio works perfectly fine.
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
