Results 1 to 12 of 12
    Established Member Two Rings roydle's Avatar
    Oct 25 2015
    FL
    Stage 1 with Dsg/Tcu tune
    Planning in flashing to stage 1 (apr or giac). By adding the Dsg tune, will the fart between shifts go away? I tried searching the forum but could not get the exact answer. Also is it worth the extra $$$$. By getting the ECU stage 1 will it suffice? Or having this platform is the dsg tune a must? Feedback appreciated. Thanks.
    Mar 21 2015
    The fart is there to stay. The tcu tune is not a must but is very nice. APR website will tell you all of the benifits of their tcu tune.
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hello,
    I have APR Stg1 ECU + TCU tune. It's a verry nice combo !
    (i like the auto up/down shift disabling features, and the rpm limit rasied since i have a 8.5)
    I think that the DSG Fart is far less now with the TCU tune.
    Best regards,
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Fart gets louder with tunes
    Dec 12 2015
    Montreal
    TCU tune on stage 1 is not necessary but it's nice to have. On the other hand, if you decide to go stage 2, you might need to put the TCU or you might experience hesitation or clutch slip between gears, due to the extra torque. I could confirm you that TCU + Stage 2 = no more fart at all.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    EPL Stage 1 and DSG tune here, fart is more pronounced. Love it.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by Ti Chen View Post
    ^^ not true at all. Farts don't go away with APR's tunes at all. If anything they will be a bit louder and you'll feel the car shift amazingly fast/faster. You won't (unless you have a problem already) see any slippage with the DSG Either. 6spd clutch is the weak point there, but not on the DSG.
    Also, get the DSG Tune as it will open up the RPM's on your car to 7200 vs the short shifted version the B8.5's are cursed with from the factory.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Why no more fart? Considering stage 2 with TCU and would hate to lose the exhaust farts.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    APR's dsg tune keeps the "farts." Only when you enter AMAX mode do the blip upshifts disappear
    TCU tune is really worth it on a facelift model because of the lower redline from factory. Also is said to address some of the dsg quirks like the 2-1 downshift. I'd skip it at stg 1 for a 10-12 MY
    Oct 25 2015
    FL
    If the fart is more pronounced with the tune even better. Not sure why Ti Chen experienced the opposite.
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by mrmomo313 View Post
    For the 2015's, the 2-1 downshift is very smooth and only does it if the car comes to a complete stop. I have noticed this when approaching stop signs and the car keeps it in 2nd when it is barely in motion and will not change it to 1st, which is great.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Dec 12 2015
    Montreal
    I should have specified that I don't have APR tune, my bad :). I have REVO stage 1+ (which is the equivalent of APR stage 2). I didn't put the TCU at first, I went only the REVO ECU tune stage 1+. The fart was already less pronounced. After tuning the ECU stage 1+, I found my DSG tranny hesitation or clutch slip feeling between the 1st and 2nd shift. After installing the REVO DSG tune, the hesitation or clutch slip is completely disappeared. Now all my shifts are fast and firm. As for the farts sound, it completely disappeared.
    Well that's my experience with REVO and very happy with it!
