Results 1 to 7 of 7
    Established Member Two Rings btvm92's Avatar
    May 25 2015
    2003 Audi S8 Exclusive Edition
    Jonesboro, AR
    Sudden Coolant Leak A6 2.7t
    I came out this morning to this large puddle under my car
    Starting at the front right side of the motor
    There are drips all over the front right side of the motor but appear to be coming from further up.
    It does not appear to be coming from the lower radiator hose.
    The only thing I can think in that area would be the thermostat or maybe aux water pump? However, I just did a complete timing belt/ water pump/thermostat job about 5 months ago and everything has been fine since. I also took a close look at the aux water pump while in there and did not see anything suspicious.
    This all happened overnight, my car is still running at temp, but I noticed that either after running for a bit, OR after the level gets low enough, it will stop leaking.. I came out to the puddle, topped off w water, drove for about an hour and it leaked back down to the same level it was when I first discovered it.
    This is w the car off. Is this a dangerous level to be driving on?
    Aug 04 2009
    Glen Ellyn, IL
    It's fine to drive at that level, but of course you'll want the leak fixed.
    Common leak points are the tank (cracks), plastic tstat housing and the aux pump. How good of a look did you get of the aux pump? I'd suggest taking 5 mns once the engine has cooled a bit and taking the y pipe off and seeing if it's wet in there.
    Your 01 should have a metal tstat housing and the leak I on the wrong side of the engine for it to be the tank.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Veteran Member Three Rings achb5's Avatar
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    I just fixed a coolant leak on my AR, the o-ring to the temp switch failed, basically crumbled apart with age and heat. its in the Passenger side in the coolant hard pipe. Might be worth taking a look.
    Aug 04 2009
    Glen Ellyn, IL
    I think that's going to be too low to be causing this leak, but you're right. That should be added to the common leak spots.
    @fourings | Build
    May 25 2015
    Jonesboro, AR
    Quote Originally Posted by 4rings2turbos View Post
    During timing belt job I had valve covers off and got a fairly good look underneath the intake manifold and it appeared to be dry. Next chance I get I'll get in there and look at it. I do have the metal tstat housing and like I said this came out of nowhere. I'm hoping its a simple hose or something but I'm having trouble finding the source, I read from someone who had a leak in a similar place that it was a plastic elbow from one of the heater core hoses?
    Quote Originally Posted by achb5 View Post
    The sensor located ON the lower radiator hose? That's the first place I looked and everything seems dry down there, the leak appears to be dripping from directly underneath the front right side of the oil pan.
    Established Member Two Rings urAllroad's Avatar
    Jul 24 2013
    SF
    Quote Originally Posted by btvm92 View Post
    No, the switch in question is located on the right side of the vehicle (passenger) between the motor and the firewall. There is a coolant crossover pipe connecting the two heads, with sensors plugged into it. To gain access you'd need to take out your intake accordion and perhaps a few other things, at least just for inspection.
    WTB: allroad mudflaps
    Current:
    2003 Audi allroad 2.7T 6MT (The daily for my daily)
    1991 VW GTI with 12v VR6 swap (The daily)
    1986 VW Golf Diesel (45+ MPG Project)
    Established Member Two Rings Black-Forest's Avatar
    Jan 09 2016
    Mercedes 600SL, 190E 16V, 03 JCW, 04 Dinan Mini Cooper
    PNW
    Looks to me to be the radiator hose. How did you make out with the diag and repair?
    Old enough to know better but young enough not to listen...
