Results 1 to 40 of 44
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    RS5 FTG measurements - I'll start
    I've seen lots off talk about this but haven't seen a dedicated thread. If would be great to see this with various combinations of springs and suspensions. So I'll start.
    Stock RS5 suspension with a full tank of gas on 275/30/20 tires.
    Rear: 27"
    Front: 27.25"
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Rechecked
    Feb 04 2010
    Ottawa, Canada
    F - 27 1/4
    R - 27
    Full Tank
    Stock Suspention
    19" Winters (235/40/19)
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance (on order)
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    http://www.audizine.com/forum/showth...-Sport-Springs
    26.57" Front 67.5cm
    26.65" Rear 67.7cm
    Eibach Pro Kit (made for V8 S5)
    Audi DRC suspension
    20" wheels
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by JamesRS5 View Post
    26.57" Front 67.5cm
    26.65" Rear 67.7cm
    Thanks James. Your thread is well detailed and extremely helpful.
    Feb 27 2014
    Dubai
    I'm one of those nerds who love the science behind how everything works.
    Jan 07 2011
    2013 C300 4Matic
    i know a few rs5's that's gonna b like 20 FTG (;
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Three Rings cmoore86's Avatar
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Front 25 3/4"
    Rear 26 3/8"
    Billstein iRC Coilovers
    OEM Rotors 275/30/20
    2018 Audi [] SQ5: Navarra Blue | BBS | AWE | 034 |
    Sold - 2015 Audi RS5: Sepang Blue My Sepang Blue RS5
    Sold - 2015 Audi SQ5: Sepang Blue cmoore86 2015 SQ5
    Sep 13 2014
    New York
    I just rechecked on flat ground and with a yard stick. 26 1/4 front and 26 3/4 rear.
    HR oe
    So eibach should me 1/4 higher in front and 1/10 lower in rear.
    Feb 27 2014
    Dubai
    Jimmy, remember I'm on the DRC suspension which uses pressurised dampers at 19 bar so your ride height may well be lower?
    Sep 13 2014
    New York
    Well it seems like my car is matching HR oe lowering specs for rs5? I did see a pic of members car here that he sold (rs5) on eibach springs. It looked a little higher in the front than my car. I'm waiting for my kit to come in. I did order the b12.
    Feb 27 2014
    Dubai
    I'm sure you'll love it, the ride is very good.
    Sep 13 2014
    New York
    Anybody have a 2008-2012 stock s5 ride height?
    Feb 27 2014
    Dubai
    Jimmy, this is taken from A5OC on a discussion on ride height between S5 and RS5:
    Not sure where the 30mm spec is coming from. I've owned two S5's and two RS5's ( all pre face lift ) and the RS5 is only 3mm lower. Which is what the brochures say as well. Road to wheel arch is 689mm front and 695mm rear. Wheel size makes almost no difference because tyre aspect ratios differ such that rolling diameter is maintained.
    This ties in with my previous ride height and the drop I got with the Eibachs.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    So Stock S5 is 27 1/8 f and 27 5/16 r.. Interesting that the RS5 sits a hair lower and has negative rake dialed in stock form vs. the S5.
    Sep 13 2014
    New York
    So a rs5 w eibach springs should be around 1 inch front and around 3/4 rear. Not much of a difference you will see with naked eye
    Feb 27 2014
    Dubai
    I don't tend to use medieval inches, they serve no purpose in modern life other than to confuse the shit out of people....but yes.
    remember the RS is 80kg heavier so will sit a little lower.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    I was compelled to convert for my own sake, sorry for the confusion. Us mericans have trouble thinking in metric.
    Feb 27 2014
    Dubai
    Haha, how can the metric system be confusing, it's so simple even I can use it.
    But hey, if you mericans are happy and why wouldn't you be, its only 2016 and you're an industrialised modern superpower so using a system of measurement based on a barley corn length makes complete sense....right?
    So if 3 barley corns = 1 inch then my car sits 8.85 barley corns high or to make it easy 0.738 yards. Simple
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    ^ This is awesome. I learned something new today.
    Sep 13 2014
    New York
    I prefer steak fries over corn on the cob.
    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    25 1/4" all around
    Bilstein PSS10 with room to go lower, stern adjustable control arms
    20x10 et25 Klassen M55
    275/30/20 Pzero Corsa
    I would go lower, but this is as low as I can be to comfortably pull into my driveway.
    R8 V10 Supercharged
    8V.2 RS3 grocery getter
    A few A4 Avants
    Feb 27 2014
    Dubai
    I don't think you need to go any lower, it looks perfect as it it.
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    I agree. That drop looks spectacular. Any lower and you start to mess with the lines of the car.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    Late to the party.
    I'm 26 1/4" front and rears.
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Jun 13 2009
    26.25" Fronts
    26.50" Rears
    KW H.A.S.
    2023 Q5 2.0 Technik
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by adbender View Post
    26.25" Fronts
    26.50" Rears
    KW H.A.S.
    Do you have any side pics of what this drop looks like? I'm ordering my HAS kit today.
    Jun 13 2009
    I will take some. Springs just settled and it's snowing like hell.
    Loved the drop I got on my S4 and the RS5 with them..
    2023 Q5 2.0 Technik
    Established Member Two Rings A4toRS4's Avatar
    May 30 2012
    portland oregon
    V8Star, is your car for sale or did you just purchase it. I saw it for sale not that long ago and was looking at that one before I got mine. Nice ride!
    Old cars:
    B5 Audi S4
    B6 Audi A4 Ultrasport
    B7 Audi RS4
    current Car:
    2013 Audi RS5 Suzuka grey
    [LIST][*]H&R sport springs[*]20x10.5 BBS CH-R wheels[*]Eventuri Intake
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    No problem... Just curious. My kit is on its way .
    Jun 13 2009
    Quote Originally Posted by Gonzoe11 View Post
    Couple of quickies...
    2023 Q5 2.0 Technik
    Feb 27 2014
    Dubai
    Is that one of those machines that clean the ice rink?
    Zamboni RS5
    Jun 13 2009
    Zamboni RS5
    30 minutes before
    2023 Q5 2.0 Technik
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Are those 19"for winter?
    Jun 13 2009
    yes...19x8.5 CH-R on 255s
    2023 Q5 2.0 Technik
    Jun 08 2010
    Quote Originally Posted by A4toRS4 View Post
    It's still for sale, though I am not in a rush to move it.
    R8 V10 Supercharged
    A few A4 Avants
    Jun 11 2013
    Garabage can, Brooms, and stuff
    WA
    I have a question for all of you who lowered your car. Every since I lowered mine, I noticed this intermittent mechanical thumping sound when I turn the steering wheel all the way left or right. Originally I thought it was the wheel rubbing the fenders but there is no sign of it. It only happens at full lock. Any idea what that might be?
    2013 RS5 | Daytona Gray Pearl | Ti-pkg | MMI | Sports Exhaust | Leather/Alcantara Sports Seats | Power Rear Sunshade | Xpel Ultimate full front wrap | 3M color stable 35% tint | GMG Springs | Eurocode Alu-Kreuz | Eurocode USS Sway bars | USS billet F/R Endlinks | Eurocode/SPC Motorsports UCA | HRE P107 20x10.5 ET25 Brushed Copper Finish | Michelin PSS 285/30/20 |
    Feb 27 2014
    Dubai
    Quote Originally Posted by TW_RS5 View Post
    Open the hood and pop off the rubber cover over the upper suspension arms, get Mrs Wifey to turn the wheel lock to lock and see if there's any mechanical contact going on. It may just be the springs moving in the seat or it may be the upper arms contacting the body.
    How low are you?
    Veteran Member Three Rings AbeViator's Avatar
    Aug 16 2013
    Is there any modification to the stock bumpstops required to use the H&R OE springs on the RS5? Also since I'm not going for the slammed look, what type of wear should I expect over normal on the OEM shocks?
    RS5 SB | Alu-Optic | Sport Exhaust | 20" Rotors | Driver Pkg w/ Side Assist | Nappa | MMI Nav+ | B&O
    CARBON OPTICS | AWE DP | H&R | 1SECARBON | 034 | ECS | EVENTURI | CAPRISTO | ARMASPEED
    Sep 28 2010
    NW NC / DE
    @AbeViator What did you get??
