Results 1 to 9 of 9
    Senior Member Three Rings brooklynA42004's Avatar
    Jan 10 2014
    2005 s4, 2004 a4 1.8T, 2010 Mercedes AMG E63, 2005 Tahoe Z71
    New York
    B6 S4 Hood Blinking on cluster??
    Hood is closed but it is blinking on the cluster anyone know if there's a pin or something? I opened and closed a few times but still blinking.
    2004 A4 2004 1.8T - DD Dolphin Gray
    2005 S4 Silver
    2005 Tahoe Z71
    2010 Mercedes AMG E63 Steel Gray
    Raptor 660 - KFX 400 - DS250 - 250EX
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Quote Originally Posted by brooklynA42004 View Post
    Maybe its the hoodline blink?
    On a serious note theres a sensor that is probably broken. Dont remember where it was tho.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    where is the hood sensor lol ?
    Jan 17 2014
    New Jersey
    Its built in into hood latch. If the light stays on it means circut is closed (closed loop) so either way you need to clean it up with some electric cleaner or replace the latch, or cut one of the wires to trick the alarm, but then it will think that the hood is closed all the time.
    Insta: luccamentone
    Jan 10 2014
    New York
    Quote Originally Posted by Lucca M View Post
    Thanks are the wires/connector under the hood latch because I didn't see any.
    2005 S4 Silver
    2005 Tahoe Z71
    Jan 17 2014
    New Jersey
    With a light you can see the wires coming up between the fans and going to a switch on the left side of the latch. When the switch is closed (your hood is closed) the signal to the alarm is open and when the switch is open (hood opened) the signal to the switch is closed.
    Insta: luccamentone
    Jan 10 2014
    New York
    anyone change this sensor? is it easy? guess mine is on its was out BC my alarm keeps going off every few hours!
    2005 S4 Silver
    2005 Tahoe Z71
    Jan 17 2014
    New Jersey
    Theres a diy on youtube just google it audi b6 hood latch
    Insta: luccamentone
    Jan 10 2014
    New York
    It must be me but I can't find it anywhere anyone have a link for a DIY? currently have to leave my doors unlocked so the alarm doesn't go off.
    2005 S4 Silver
    2005 Tahoe Z71
