Originally Posted by
JDillon15
A agree with using the 18s. You can still run a 235/40/18 tire and they look great.Spacers can be added after dependign what you need/want
trj
Personally I'd go with 18s. I think 17s still look a bit small on a b7. It depends on the wheel style as well. Split 5 17" wheels which come with most b7s look fine too.
For the spacers, it depends on wheel width and offset. I do not like using spacers. Try finding the wheels with correct offset and hub size from the get go. But if you like the wheels and only offset is holding you off, go for them and use spacers. However, I will definitely recommend against hub conversion rings plus spacers. I just don't like the idea of two extra parts to hold the wheels to the hub. Even a small imperfection on the machining of spacers/ conversion rings can be a cause of vibration in certain speeds. I've had fair share of headache chasing vibration with spacers in my other car.
Change the tires to all new if possible.
Yeah, I would prefer the 18s as well... I've wanted 18s for a while but the 18s that I'm currently looking at have 2 worn tires & slight curb rash... so I'll have to replace them quickly and the entire point of changing wheels for me is to get tires as well. It also doesn't make much sense for me to only replace 2 tires, might as well put new ones on all 4. And the seller is about 70mi from me... So, it seems moot to get new wheels... :( Whereas the 17s come with pretty much brand new tires and they're the same price!
Btw, below are the 17s & 18s. Both are stock B8 wheels... I'm hoping they look good with the curvier body of the B7.
http://imgur.com/a/OUJ0Z - The picture with 2 wheels is 17" & the other is 18".
