Results 1 to 30 of 30
Thread: Brakes & Rotors
    Senior Member Two Rings audimanstan's Avatar
    May 04 2014
    Indiana
    Brakes & Rotors
    Ive always ran OEM for breaks and rotors want to try something different. Curious as to what are you guys running as your brakes & rotors combination. After reading extensive amount of forums, I still dont know what would be a good combination of brakes and rotors. Ive read a lot of guys (different models) running on the ECS cross and drilled rotors + Hawk HPS. Is anyone running that set up with the A6 C6?
    More than likely I will be going with the ECS rotors over Adams. After all the forums I have read there is no defined answer as to why Adams are better quality than ECS. Basically when you are buying Adams you are paying extra $150 for the exclusivity of having rotors made specifically to your request and patterns. Ive heard a lot of pros about both products and very few cons. (Correct me if I am wrong!)
    As for breaks pads I always ran OEM, what would be the best break pad choice for the aftermarket rotors? Or in general what are the best quality brake pads?
    (Most important is that I still want to stop on a dime! Second is to have no noise! Third, it would be nice to have less dust brakes and rust.(OEM gives out tons dust and rust!))
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    First time I needed to replace my rotors and pads I went with R1 cross drilled and slotted rotors with posi quiet ceramic pads, no complaints from that setup at all. This last time I went with Adam's rotors in the same pattern since the price was pretty much the same and stick with the posi quiet pads though I know a lot of people use the akebono ceramic pads and have given glittering reviews on those too.
    Sent from my VS985 4G using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Jul 17 2011
    Sin City, USA
    I am running Adams rotors work Akebono Euro pads. I love the setup and have ZERO issues.
    '09 C6.5 A6
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by audimanstan View Post
    This is accurate. Adams simply takes blank rotors made by other manufacturers and machines the patterns into them (and also puts a coating on some, I believe). Prices are a bit higher than most, as you've found.
    Stoptech rotors are a good option, too. They're offered in drilled, slotted, or a combination of both, and come in roughly $75 cheaper for the set of four (compared to Adam's), with shipping. I'm sure ECS rotors are a fine option, too.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 29 2015
    London, Uk
    I've stock disks on my 07 S6 ( or rotors as you chaps across the pond refer to them) but have EBC Yellow pads. I tried the EBC Reds but for my daily drive of stop start commuting would not get warm enough to work properly in winter and on the one and only stretch of road where I could open the car up they were less than useless, opening the door might have stopped me quicker!! The yellows are great pads and a very significant improvement on the OEM pads and work really well under normal diving conditions and when driving in three figure territory they feel very powerful and secure.
    Feb 06 2013
    CA
    I run Brembo NOS (new old stock - made in Italy) rotors and Akebono pads...great stopping and very little to no brake dust...love them
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by Purpleaardvark View Post
    Very weird since the Yellowstuff pads are optimized for a higher temperature range than the Reds. The Redstuff should have had more cold bite, while the Yellow should have less cold bite but better fade resistance at higher temps.
    Either way, I'm glad you found something that works well and that you're enjoying your setup.
    -Hayden
    Sep 30 2015
    NJ/NYC
    I just replaced both front and rear pads with posi quiet ceramic pads with stock rotors and so far so good. You don't get as good as a bite as the oem pads but the reduction in brake dust is well worth it. Only issue i'm having is that the brake pad warning light won't go away after replacing the sensors. If anyone can chime in if a vag com is needed to reset this or it should go away on its own.
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    I have the ECS rotors and the Akebono pads and I'm very happy.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Aug 29 2015
    London, Uk
    Quote Originally Posted by LINDW4LL View Post
    That's what I would have thought too but I spoke to their tech guru Bart and apparently they've revised the formulation of the yellow's and it effectively makes the Red's redundant
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    I have some crap that the PO put on there that is squealing like a stuck pig at lights. The rotors look decent so I won't be replacing them yet, but I did buy a full set of Akebono Euros ( I put them on all my cars), new Carlson clips and lube. I will do a full bleed and replace all pads/clips next weekend. Maybe new rotors next pad set. I'm saving for suspension.
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by D's Avant View Post
    Thanks for the order! Glad you are enjoying them.
    Jason
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    +1 here on the Akebono pads. Never used them before this car, but I'm a big fan.
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
    Established Member Two Rings Bklynjay's Avatar
    Jul 10 2012
    Brooklyn, NY
    Background: Daily driver, neverplan on track, spirited driving here and there. But usually be on street, Belt Pkwy and ugly ass BQE. Occasional highway drives to Virginia or Rhode Island. You can see GIAC Stage I , maybe Stage 2 this summer.
    Leaning towards either ECS slotted, Stoptech Slotted or EBC slotted (if they make one for us) but pads is up in the air. Priorities for pads are NO noise, bite, then dust. Was thinking of EBC Red Stuff or Hawks but heard horror stories. Then Akebono Euro Ceramic but heard the bite during cold weather for ceramics aren't great. NYC can have bad winters.
    More input would be great!
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    Be aware, if you're doing them yourself. When I did mine on my 2006 A6 S-Line, I didn't realize I needed vagcom to electronically push the pistons back in on my rear brakes. You could not do it manually or by hand. It had to be by the computer.
    Maybe because I had the Electro Magnetic Rears, but just a heads up.
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Feb 19 2013
    Quote Originally Posted by Bklynjay View Post
    Akebonos have never been about strong initial bite, but they have a good consistent and linear build up of stopping power. I think their biggest draw is the low dust and noise. They certainly will not have the bite of a semi-metallic pad, but the dust will be considerably lessened.
    BTW, I just found an unopened bottle of 'illegal' ATE Super Blue in the back of my storage
    Dead:
    Jul 17 2011
    Sin City, USA
    Based on how you described your driving, I would go with the Akebono pads. I have them on my car (using Adams Rotors) and love them. I wont do any different pads.
    '09 C6.5 A6
    Jul 10 2012
    Brooklyn, NY
    Thanks for the advice. With that said, I am changing only the front right now but would I need vag-com to do it myself? I was under the impression for the front there are no special tools needed except pushing the caliper pistons back.
    Now leaning towards Akebono Euro Ceramic from above suggestions. It also has the sensor built in so that's a plus.
    Is this the right Part Number for Akebono's EUR1111?
    2010 A6.5 Quattro | G.I.A.C Stage I | Ibis white | Prestige Package | Side assist and cold weather package | 10% tint all around | Tinted tails | Debadged - only rear Audi Black rings | 7" TV headrest OEM bolt on with MMI | 2013 S4 19" Peelers | K6 Eyelids | Quad Rear Diffuser with Porsche 911 Exhaust Tips | Aluminum Pedals | DRL Fog LED Strip with on/off switch
    Apr 07 2010
    2019 A4, 2018 Subaru Outback
    Southington, CT
    No special tools are required for the front pads and rotors.
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Correct, for the front you can do them but due to the electronic brakes in the rear you need a VAGCOM to push the rear pistons in and cannot force it by hand.
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Feb 19 2013
    If you're not afraid of 12V, it can be done without VAGCOM:
    http://www.a5oc.com/forums/a5-s5-top...b-without.html
    (basically involves sending 12V to the circuit at the motor and checking that you have polarity right)
    Dead:
    Jun 28 2018
    Michigan
    About to put on Zimmerman rotors with Brembo and textar pads on my A6. Going to use my $20 Bluetooth OBD from Carista for the EPB.
    Jun 19 2017
    ABQ NM
    Which drill slot dimple pattern?
    Mine - 07 S6 Stock
    Wife's 07 A8L 4.2
    Jan 28 2010
    Central NY
    Akebono pads are great for avoiding dust build up BUT if Emergency/Panic stop situations are high on your priority list I would avoid them! I've used them on RWD 6cyl Volvo's and B5A4 & C5A6 Avant & they're very quiet & smooth but DO NOT give me the instant bite I want when avoiding whitetail deer & manure spreaders which abound on our poor secondary roads in Central NY! I've been very happy with Zimmerman rotors & Textar OEM type pads! Dirty but safe!
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by stuffinder View Post
    I have not experienced any issues with panic stops with my Akebono pads. I have had a few instances where I have had to stand my car on its nose to avoid nailing some stupid driver not paying attention. May be climate/temp related as you are in Central NY (humid and cold) whereas I am in the desert (dry and generally warm).
    '09 C6.5 A6
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    Thanks for the feedback.
    Mar 04 2018
    Virginia
    Thanks for the feedback SinCity. I am in a climate closer to stuffinder since I am in VA. But I think I am willing to take my chances with the akebono because I HATE the brake dust that I am getting from the OEM ones. I appreciate stuffinder's input but I don't think the akebono would be "unsafe".
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    R1 concepts drilled and slotted with the OEMP pads that they sell....after initial break in, bite is like OEM, still a bit dusty, but love having to pull the eyeballs off the dash when you mash the brakes.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Feb 19 2013
    Quote Originally Posted by akingzkid View Post
    They aren't unsafe, it's just that their pressure curve is different from semi-metallics. True, that you don't get the same initial bite and will require a little more pedal travel to reach the same braking force, but they should not be considered less safe. In a panic stop situation where you are reaching into the dynamic friction zone of the tires during ABS, it makes no difference. What 'may' make a difference is how the car is able to modulate the brake force to keep the wheels from slipping.
    We'd have to do some extensive scientific tests to get to that conclusion, though.
    Here's a good article with some testing done. Conclusion: Ceramics are less consistent than semi-metallics, but mostly in racing type conditions where heat will build up in the system. http://www.hendonpub.com/resources/a...etails?id=1569
    Dead:
    Mar 04 2018
    Virginia
    Quote Originally Posted by cal3thousand View Post
    Thanks Cal.
