Results 1 to 2 of 2
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Transmission issue? Help please.
    Hey Guys.
    Hoping for some assistance with a few symptoms I've been having.
    I've done a fair few searches and also had a couple guys look at the car but can't seem to find anything wrong (no codes) and I had the fluid changed about 5000kms ago but symptoms still there.
    My car is a B7 A4 2.0T Q Tip and largely stock (only engine upgrade really has been a DV+) and cam follower was changed within 10000km ago (old one was in perfect though)
    So the symptoms
    - slightly rough idle - normally when my car is running well idle speed is 830rpm and you can't feel a thing through the cabin. However these days it is sitting around 780 with some vibrations through the cabin. Not enough to be uncomfortable, but enough to notice. Previously I have had periods where this has gone after adding injector cleaner to the tank but haven't been able to repeat the trick.
    -when the car is warm especially (I mean driving around for a good 30minutes +) rolling to a stop the car will be sticking in 2nd until the vehicle is all but stopped and then lurch into 1st.
    -on third when I go completely off throttle and then put my foot down (even under light acceleration) I can feel a little thump or clunk of somethings engaging.
    -2nd to third gear shifts sorta lurch, slip and are delayed , especially when driving more aggressively - I have attached a video and you can see how the gear change sorta has two RPM drops which doesn't happen elsewhere. . Again this happens only after the car has Been really warmed up.
    If anyone has any ideas that would be causing this that would appreciated! Thanks.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Oct 24 2015
    Perth, WA
    Clutch plate
    My respray thread
