So I bought an A4 B5 from a friend and I have no idea whats been replaced on the car, so the question is..
Doing a timing belt replacement, what are all the parts that you can replace while the front end is off.
I have bought that kit from ECS Tuning which includes:
Timing Belt
Tensioner
Tensioner roller
Idler Roller
Water Pump w/ Gasket & O-Rings (Featuring a Metal Impeller)
Water Pump Housing
Thermostat w/ O-Ring
Thermostat Housing
A/C Accessory Belt
Power Steering/Water Pump Accessory Belt
Alternator Accessory Belt
Front Camshaft Seal
Front Crankshaft Seal
Intermediate Shaft Seal
Crank Pulley Hardware
I'm also going to replace my A/C Compressor, and A/C Condenser due to previous owners botched repair job on my A/C Lines(stripped the threads putting a new line on).
So I'm looking to do a fairly large overhaul while it's open.
What are all the parts that I can replace while I'm elbow deep.
My Car is an A4 B5 1998 1.8T with 215,000 miles on it.
