    Veteran Member Three Rings jamin_00's Avatar
    Sep 14 2014
    Essex, UK
    Just sealed my wheels!!
    Some of you may find this interesting.
    I use Krystal Kleen Details R Evolve X. Its normally applied in 2 methods, apply a nice layer smoothly and leave or apply 2 layers with buffing after each application. The latter method is better if your not comfortable applying ceramics as its easier to get a smear free finish.
    However, there is a third and I use that method. Airbrush neat product. For intricate design wheels its much easier than trying to get some applicator in to those awkward parts and when you only have around 10mins before the product starts to harden then this really is the best way.
    A quick vid. 2 coats on to every surface. By this I mean I would do the left hand side of the spokes first moving in a clockwise direction twice. Then the right hand side of the spoke etc and continue this until every different aspect had 2 coats. Then do a general spray over and check for defects. If any are there simply buff then reapply. It took me around 5-7mins to do a wheel and thats being generous. He's a very quick vid and some pics below. The coating does apply a gloss so these are satin bronze and it will give them a bit of a shine. If applying to a matt finish wheel it will make it more satin.
    Even though brand new, unprepared and dirty. A quick wipe down with an IPA mix and good to go.
    Cleaned and coated and after spending 5 mins in front of a heater to help the product flash in this cold weather.
    On the left, untreated, on the right treated and after 5 mins in front of the heater. Heater not needed if in above 8deg C or so.
    The cheap airbrush unit from eBay :)
    Audi S5 V6T 3.0 - Black Edition - Stage 2 MRC Tuning - 480bhp 580nm
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    Is this similar to say Carbon Collective wheel coating? Protects wheels and easier to wash off dirt? Your wheels actually look better after you treated them. Very nice look!
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by Canadianwraith View Post
    +1 Right side looks great.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Veteran Member Three Rings Diamond Dog's Avatar
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    You should post this in the detailing forums. Need more posts aside from the "sponsored" products.
    Sep 14 2014
    Essex, UK
    I do not know what the CC one is, but yes, they protect for a couple of years and do make it easier to wash as the hot brake dust and road grime can't bond as well to the surface. Same as a body ceramic but this is harder.
    Quote Originally Posted by Gonzoe11 View Post
    I think its looks better too. They cured now but when I get them out I will do a side by side pic from before.
    Quote Originally Posted by Diamond Dog View Post
    OK, I'll look it up.
