Results 1 to 9 of 9
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Time for a little update on the A4...
    It is now in for a complete paint job and some body work...
    Including modifying the front and rear Rieger bumper assemblies.
    Originally I wanted to finish the underneath of the car with a flat bottom, rear diffuser and front splitter but that will have to wait for next year now ($$$) however we did close off the underneath of the front end but pictures will be forthcoming once we reassemble the car after the paint job and dyno tuning.
    For now some of the body work prior to the primer and paint being sprayed...
    For those who might know the Rieger front bumper cover, we have here 3 mods done to it. One, the central opening was reduced to get the air to flow directly into the intercooler. Two, and upper opening was created to allow air into the power steering cooler. Three, custom made brake cooling ducts were made.
    Here is approximately the amount of material (in this case fiberglass) that was added each side to reduce the main opening on both sides. You can also see the front end view of the brake ducts.
    Here's a close up of the brake duct. They are made of the same ABS plastic as the Rieger bumper covers. We used a specialist in plastics welding to blend/weld the pieces together.
    Here's the back side of the ABS duct that flows into a 3 inch round ABS tube that was molded and then welded to the main duct.
    A view of the duct where it is mated by welding to the Rieger bumper. You can clearly see here the weld bead that makes the duct.
    Very close, close up of the welding of the Rieger bumper and the air duct.
    Back side view of the central opening of the Rieger bumper with the two fiberglass pieces to reduce its opening.
    Close up of one of those pieces. However we noticed that since the fiberglass pieces were very stiff and the ABS Rieger bumper less so, cracks were forming between the two materials so we decided to remove these fiberglass inserts and replace them with an ABS version.
    Here's one front view of the ABS version.
    Here's another front view of the ABS version.
    Here's the backside view of the ABS version.
    Here we have the Rieger rear bumper cover. It was extensively modified in preparation for a diffuser in the future.
    General body work being done around the car.
    Front end showing the power steering cooler above the intercooler.
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Fuck Yeah
    Aug 19 2013
    minnesota
    Woe
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Always enjoy the updates!
    Daniel J
    @gtg_drives
    Oct 30 2006
    B8 A4 Avant 6spd
    I'll trade you my PSS9s for your Ohlins?
    -18 718 GTS
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by Militant-Grunt View Post
    No those are the brand new TTX Ohlins but I can sell you my old STaSIS/Ohlins Motorsports kit. :-)
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by Jet Jockey View Post
    Hehe, I was mostly just joking. It would be a shame to ruin that kind of coilover on the streets of New York.
    Would you be able to provide a better set of photos of the brake cooling ducts though? How do you have the piping mounted?
    -18 718 GTS
    Jun 17 2004
    Montreal, Canada.
    Running in the streets would not ruin the STaSIS/Ohlins... you cannot compare the PSS9s to the Ohlin kit, they are day and night in comparison... way superior in handling and ride comfort!
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Sweet.. Cant wait to see after paint!
    2013 Solar Orange S4
    6MT | APR stage 2+ Ultra | Eurocode Headers | APR CPS | Meisterwerk clutch | Milltek Exhaust (resonated) | KW V3 coilovers | HRE FF01 | Stoptech trophy BBK | Alu Kreuz | Eurocode Sway / Endlinks / Trans & Dif mount | LYKT Control arms | E-Codes | Eurocode Short Shifter | P3 Gauge | Vinyl roof / trim / blades | B&O / JL Sound system | Probably more..
