Results 1 to 14 of 14
    Feb 15 2016
    Oak Lawn IL
    Headrest removal
    does anyone have any ideas on how to remove the headrest on a a5? i tried looking for the push lock in the upper back of the seat and had no luck finding it? i have the electric adjustable headrest if that makes a difference.
    Feb 15 2016
    Oak Lawn IL
    Anyone?
    Established Member Two Rings jagata's Avatar
    Apr 15 2014
    So. Cal
    Reviving this old thread because I need to open up the A5 headrest so I can quiet down a slight rattle that the posts are hitting against the internal parts in the headrest itself that is very slight but enough to drive me crazy. Anyone knows how to remove them it would be very appreciated.
    Dec 20 2016
    Seattle area, WA
    I stole this image off a5oc forums.. it's in Dutch, but hopefully the image explains enough
    I think this is how I ended up adjusting the height as well.. or was that in my TT.. too late Sunday night..
    http://www.a5oc.com/forums/attachmen...6&d=1456143584
    Apr 15 2014
    So. Cal
    Thank you,
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    Were you able to adjust your headrests? I have never been able to find the button to allow them to come out.
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
    Apr 15 2014
    So. Cal
    No not yet. I'm still trying to figure out the diagram.
    Active Member One Ring a_s-Oo4's Avatar
    Oct 20 2018
    2017 Ford Escape|Titanium|White Platinum & 2007 Yamaha FZ6|Red|
    Chicago, IL
    Bump
    Does anyone have motorized headrests? My driver’s headrest doesn’t move up and down like my passenger one does. It goes up about 4mm and halts. I’m not sure if it is stuck on something or what. Maybe I have to remove it... has this “hidden button” worked for anyone? Any insight would be much appreciated.
    2011 A5 Prestige S-line | Ibis White | 6MT | RS-5 pedals | WeatherTech liners | Audison Voce |
    more to come...
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by a_s-Oo4 View Post
    Bump
    Stupid question, you do know that on the side of the seat, moving the vertical seatback knob up/down controls the head rest. Took me a while to realize this.
    Oct 20 2018
    Chicago, IL
    Quote Originally Posted by Neil F View Post
    Ha! Yeah I'm aware of the headrest/vertical knob... Problem is that the it only goes up slightly on my driver's side, but fully on my passenger's. I'm not sure if the lack of movement is a safety feature for the driver or what... I'll try and post a picture later today.
    more to come...
    Jan 13 2017
    marlton/nj/usa
    I have full range of motion on my drivers side
    Oct 20 2018
    Chicago, IL
    First image is the driver side that doesn’t seem to reach the full height potential. The second image is the passenger side which I assume is the height both headrests should reach.
    more to come...
    May 12 2017
    Steel City, USA
    Have you tried tilting the driver seat back or forward and see if it goes higher?
    -Joe
    Oct 20 2018
    Chicago, IL
    Quote Originally Posted by snocat17 View Post
    I’ve tried the tilting method you speak of. I feel like the headrest is caught on something internally in the seat... Is taking the seat material off somewhat easy? I feel like it’s the only way I’m going to be able to acces the headrest posts and hidden removal button.
    more to come...
