Results 1 to 32 of 32
    Veteran Member Three Rings turbojayc's Avatar
    Sep 11 2015
    Homelink is TERRIBLE!
    Anybody else have issues with their Homelink and it being absolute crap. The range on mine is terrible and I basically have to pull right up to the front of my door facing forward. (Which is an inconvenience as I always back in). It's not the opener as my wife can open the garage from down the street with the remote that came with the unit.
    Any fixes?
    2023 S3 - Daytona Grey Pearl | H&R Sport Spring | 19" Rotiform OZR | Unitronic Stage 1+
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i haven't had any problems with mine. as with most car garage door opener modules, it is directional
    in fact just last night when headed home i got a new record for distance, probably a good 100 yards down the street through a window in the side of our garage
    Mar 21 2015
    I have to be within 100ft for mine to work
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    No issues here on any of my cars '06,'08,'14.'16. I haven't done a distance test, but I routinely open my doors before I enter my driveway. Have you tried different combinations of pressing vs holding the button?
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    mine is intermittently bad/good. i live in an apt complex - sometimes i can be half way down the block and get it to open, other times my bumper is practically at the door with me repeated pressing the button before the door starts to move. fwiw, the homelink transmitter is mounted in the front grill of the car. when i swapped in an RSQ5 grill, the body shopped had to remove and reinstall the transmitter.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Sep 11 2015
    I seem to be the only one. I'll double check the actual unit. (Liftmaster 8500) Maybe there is an adjustment that could be done. Just seems weird as the remotes that come with the unit work great.
    Thanks everyone for chiming in.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Jan 23 2013
    CO
    At least it works in the SQ5. I also have a Lexus RC F, same model year, and Lexus could not get the homelink to work with the same garage door that the Audi can open.
    2018 Audi TT RS Ara Blue
    PAST: 2017 BMW X6M
    PAST: 2015 Daytona Gray Pearl SQ5, Tech, Lux, 21s
    PAST: 2017 Porsche 911 Miami Blue Carrera 4S
    PAST: 2015 Lexus RCF
    PAST: 2013 Phantom Black Pearl RS5, MMI, Titanium, DA
    PAST: 2011 Lexus IS-F
    PAST: 2010 Infiniti G37x
    PAST: 2009 Subaru Spec B
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    I haven't had any issues with mine. Driveway is about 120 ft to the corner of the house and it works as I approach the driveway.
    Maybe try a different channel on the unit and reprogram?
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    No persistent issues with my homelink either; however, I can recall at least two occasions when I did need to pull up close to the door for it to work.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Sep 11 2015
    Thanks again, everyone. I'll play around with some of the suggested options over the weekend.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Established Member Two Rings TopTrim's Avatar
    Oct 19 2015
    2015 SQ5 Panther Black Crystal, 2005 C6 vert w/ ECS supercharger
    It may be the antena on your opener. I pulled the wire out and coiled it around a pencil. Then removed the pencil and let the small coil dangle from the opener. I can open the door from over 100' away.
    2015 SQ5 - Panther Black Crystal, Black optics, CTS intake, Magnaflow exhaust, Ag M540 20x10 et25 w/ 275/40/20 Conti AVS, H&R (-3) springs, EBC red stuff pads.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I have heard of others having this problem, but both of mine worked fine. I back into the driveway and I press the opener from the street, facing away from the door, at around 80 feet. I have gotten in the habit of holding it for 2 seconds, otherwise it doesn't always work. This was going to be my suggestion...always hold it for 2 seconds. For those having trouble, it could also be caused by other interference in your neighborhood. Not the sort of interference that could open your door, but enough to confuse the signal.
    Nov 16 2014
    2015 SQ5, 2008 E90 M3
    md
    This homelink setup is much better than the one on my M3. Try adjusting the antenna on the garage door opener itself.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by TopTrim View Post
    woah! I didn't even think of that. no wonder our 3 doors don't open the same. will be modding my antennas soon
    Active Member Two Rings Idgreig's Avatar
    Nov 27 2013
    Ontario
    Turbojayc, any luck? I've had this same issue with same opener since I got my SQ over 2 years ago. I tried reprogramming many times and it fails periodically to open at all. There's a point 50' down the drive as I round a bend that I have to hit or I risk no response at all. I bought the "my Q" (aptly named isn't it) adapter from Chambelain for the opener itself and use my iPhone from a km away instead. Other cool features too, but I'd love to just fix the problem. Wife's car doesn't seem to struggle...
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by Idgreig View Post
    Mine was horrible for years, I recently pulled the top cover off the radiator/bumper to get to my headlights and found the homelink unit had fallen out of its center mounting clips and was just laying there. When I put everything back together it worked much better, no distance problems now.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Sep 11 2015
    Same shit. No improvement, I'm just dealing with it. Sorry, I'm not much help. I find keeping the button pressed in a few extra seconds has helped.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Apr 26 2014
    DFW
    This is always true for rolling-code openers, which are pretty much all of them made in the last decade.
    Both of mine have worked perfectly, backing in from about 80 feet away, as long as I press it for 2 seconds.
    Oct 26 2015
    los angeles/ california
    Not one single issue
    Senior Member Three Rings Drichardson72's Avatar
    Apr 11 2015
    Vancouver, Canada
    On my second Q with No issues at all.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Not sure if this adds any value, but it was a bit of a challenge programming the opener in my new '16 SQ5. Three attempts. I did everything exactly as prompted each time. Third attempt worked like a charm. I've heard others (not just Audi...although Homelink is the constant) report the same. Weird. Nonetheless, once programmed, it works just as well as it did in my '13. Feather pressure for a nanosecond on the button, and bada boom, the garage door opens.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Jan 23 2013
    CO
    Quote Originally Posted by VroomVroom View Post
    Works fine on our '15 SQ5, but not on our '15 Lexus. Go figure.
    PAST: 2017 BMW X6M
    Boston, MA USA
    Mine works perfectly fine. Same distance as the actual remote and the homelink that I had in my Lexus.
    2015 Audi Q5 2.0T Premium Plus
    2015 Audi A3 2.0T Premium Plus
    *RIP 2004 Audi S4
    Apr 13 2016
    canada
    homelink antenna
    Quote Originally Posted by turbojayc View Post
    Any fixes?
    on my 530i BMW i had the same issue.
    dealer could not address the issue
    i called Homelnk, and they send me a new device with a better antenna
    now i can open the garage 500' away
    Sep 11 2015
    Quote Originally Posted by waninae39 View Post
    Interesting..
    Who do you call and what did you change?
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Apr 13 2016
    canada
    this was a while ago. i simply called homelink and told them the issue. they said yes, this is a common issue/complaint.
    no cost at the time, they just send me a new module that replaced the old unit in the header liner.
    i guess it was no cost as the unit is useless if you don't already have the module in your car
    Sep 11 2015
    Thanks. I'll do a little digging.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Bumping this thread, I'm having literally the exact same issues. Horrible range and I always back I to my garage.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2018 Audi Q7 3.0T Glacier White/Nougat Brown
    Apr 26 2014
    DFW
    I remember this thread. Perhaps you guys are getting some interference. Probably not what you want to hear, but all three of ours work just fine from in front of the neighbor's houses, about 100 feet away. I back in too, and it works, facing away from the house in the middle of the street.
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Check the antenna on your garage door opener. Both of mine work great. I can open the garage door from three to four houses down the street.
    Sep 11 2015
    Since I started this thread, I am no longer using my Home-link. Back to the old fashion visor clip-on remote. Works perfect, every time.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Jan 23 2013
    CO
    That was what I had to do with the Lexus. I traded it - the infotainment system trackpad was unusable and the seat heaters were crap. The "Relentless Pursuit of Perfection". LMFAO
    PAST: 2017 BMW X6M
