Results 1 to 8 of 8
    Sep 16 2010
    Central Wash
    Complete pair power Folding, auto dim, heated mirrors-
    Removed from an 04' S4. I kept the mirror caps. $90 shipped. One harness was cut for removal; (not me!) but I had the end around here somewhere.
    Glass seems great, mirror caps are Atlas Gray.
    Sep 16 2010
    Central Wash
    OBO..?
    Can't think of a reason I'll need these..so..offers. The mirror glass must be worth something.
    and i found the rest of the one harness that was cut.
    Established Member Two Rings ckimble's Avatar
    May 17 2015
    San Antonio, Tx
    Do you have to have a vagcom to get them to work if you have normal mirrors?
    Sep 16 2010
    Central Wash
    Quote Originally Posted by ckimble View Post
    No, no Vag com required at all. There's no coding if you're trying to "add" these to a car that came without them. It's all wiring. Lots and lots of wiring. And a matching control module. And the right switch. And beer. Lots and lots of beer.
    May 17 2015
    San Antonio, Tx
    Hmm actually pretty interested I'd have to see if someone has a write up on here for it though I have no idea on the module and switch....the beer part is no issue.
    Sep 16 2010
    Central Wash
    If I was going to do it, which...I originally contemplated...I'd find a parts car and remove the wiring, switch and module myself to use. I don't think you could realistically do it any other way. I mean, unless I'm wrong and most of these cars came wired for them? It may only be 2 or 4 wires to add to the module / switch?
    It's usually cheaper for manufacturers to make most of the cars the same and lose $2 worth of wire than to specify a different harness for 'options' all along the assembly line.
    But..again..I dunno.
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Quote Originally Posted by rollerton View Post
    Which, I think, is the reason that the harness for the super whamadyne mirrors are installed (but not connected) in cars that don't have them.
    Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
    Sep 16 2010
    Central Wash
    I dunno. I probably wont do it.
    So..anyone want them -- make an offer
