Results 1 to 12 of 12
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Power Steering Rack is busted...
    Fricken steering rack is leaking like a siv... I just dumped 1000+ on the exhaust... this car is getting annoying. Plus I still need to fix my license plate lights... FUCK ME.
    Aug 27 2013
    Philly
    Quote Originally Posted by Gberg888 View Post
    But seriously, that sucks. Sometimes certain failures are hard to prep for.
    Apr 07 2011
    Try some Lucas Power Steering Stop Leak. It might not completely stop the leak but should certainly slow it down a lot.
    Aug 19 2013
    minnesota
    If you use the Lucas stop leak remember to heat it up on the stove a little bit and mix in some power steering fluid. The Stop Leak is very thick and it will be hard on your pump so getting it warm and mixing in a little CHF will help ease it into the motor, also add it to a warm motor.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 26 2005
    Sounds like buying the exhaust was a poor decision. The steering rack would not go from no leaks to serious leaking overnight.
    Vorsprung durch Technik
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    I agree. Maintenance < Mods...
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Feb 27 2011
    Winnipeg
    its not even that bad to change, I got a used non servotronic rack from a b7, possibly late B6 for $75, worst part is one of the banjo bolts on the rack, took me 2 hours to swap out, just make sure you replaced all the alum crush washers on the rack and you're good to go.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Quote Originally Posted by seanf86 View Post
    +2
    unless you have the 3.0 the bolt facing down is pita because of the oem cats.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Nov 11 2010
    Rochester, MN
    Quote Originally Posted by 19jdog View Post
    +2
    Right, you have to be quite the contortionist to get that one out on the 3.0. Not fun!
    19" B8 S5 Peelers
    Feb 27 2011
    Winnipeg
    +2
    Both my b6s are 1.8t I think op has a 1.8t as well, I did have a hell of a time getting the rack out if my 2.8b5 parts car so I see how it's a pain.
    Jun 16 2011
    996tt
    MA
    Had to get the exhaust to pass emissions for MA inspection, so that was a must and not really a mod, it was a horizontal move at most. Although it is quieter and passes.
    And your also wrong about the rack. For example, 4 weeks ago it needed fluid. I put some in refilling. Then when it got real cold up here last weekend i had to fill it 2 times in 3 days. That was last week. I check it literally every-time I drive because im scared of blowing up the pump if it runs without fluid for too long and keep spare fluid in my trunk. Either way, since it was cold about 1 week ago the fluid level has not lowered at all. It is extremely fucky. Checked it this am, same level as last week after I refilled it.
    Jun 16 2011
    996tt
    MA
    Quote Originally Posted by gotboost View Post
    You agree with Diag that maintenance is LESS important than mods??? You mean maintenance is Greater than mods???
