    Feb 16 2016
    Bay Area
    New B5 S4 Avant Owner - Will I pass CA Smog? - Vagcom Scan
    Greetings,
    Just bought my buddys 2001 S4 Avant (pic soon), he's had it since day 1 and taken good care. I'm new to CA and never had to pass smog before (I read it's just OBDII and not roller+sniffer?). When I got the car the CEL was on with following codes:
    17861 - Exhaust Gas Temp Sensor 1 (G235)
    P1453 - 35-00 - Open or Short to Plus
    17867 - Exhaust Gas Temp Sensor 2 (G236)
    P1459 - 35-10 - Implausible Signal - Intermittent
    16805 - Warm Up Catalyst; Bank 1
    P0421 - 35-10 - Efficiency Below Threshold - Intermittent
    I cleared them and drove around for 100 miles, then checked readiness with Vagcom and it all looks good? Is there any other tests I should check with Vagcom? Should I just cross my fingers and go smog? Thanks!
    Mode 01 - PID 01 : Readiness -- Address 10
    Number of DTCs stored: 0 -- MIL Status: MIL OFF
    Misfire monitoring: Passed
    Fuel System: Passed
    Comprehensive Components: Passed
    Catalyst monitoring: Passed
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring: Passed
    Secondary air system monitoring: Not installed.
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring: Passed
    Oxygen sensor heater monitoring: Passed
    Exhaust Gas Recirculation: Not installed.
    Ran o2 sensor test:
    TID 01 - Rich to lean sensor threshold voltage Test:0.435 V
    TID 02 - Lean to rich sensor threshold voltage Test:0.435 V
    TID 03 - Low sensor voltage for switch time calculation N/A
    TID 04 - High sensor voltage for switch time calculation N/A
    TID 05 - Rich to lean sensor switch time N/A
    TID 06 - Lean to rich sensor switch time N/A
    TID 07 - Minimum sensor voltage for test cycle Test:0.000 V - Min:0.000 V - Max:0.385 V
    TID 08 - Maximum sensor voltage for test cycle Test:0.865 V - Min:0.480 V - Max:1.005 V
    TID 09 - Time between sensor transitions Test:0.360 s - Min:0.080 s - Max:1.280 s
    TID 10 - Sensor period N/A
    Feb 21 2012
    MB S55 - (607hp/671tq), Suzuki GSXR 1000
    Chico/CA
    You just have to pass visually and readiness. Based on your above results, you should be golden, good luck.
    2000 Laser Red Stage III+
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    I thought car will fail automatically if cel is present?
    Feb 16 2016
    Bay Area
    Passed!
    I cleared the CEL and drove around for 80 miles and it stayed off.
    Sep 17 2012
    Riverside, IL
    Nice, job well done it looks like
