    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Audi B8.5 S5 GIAC stage II 1/4mile -> [email protected] (02/18/2016 time)
    Temp 68
    Humidity 37%
    Mercury 30.27
    DA 368ft
    Mods are the same as last time:
    GIAC Stage II
    GIAC TCU
    AWE-pulley
    034Motorsports throttle body boot
    AFe filter
    exhaust X-pipe mod
    Removed spare tire/jack, GIAC RACE file, 1/3 tank of gas remaining (in between the 1/2 and 1/4 tank on the gauge), Fuel = 93 octane mixed with E85 for an E38% blend with an effective octane of 97.1, Tire pressure 39/38 f/r on OEM Dunlap Sport Maxx GT. I ran 3 11.5 (one of them I posted), and about 10 11.6x slips as the night progressed and traction became an issue.
    Timeslip broken down:
    R/T .348
    60' 1.656
    330 4.781
    1/8 7.377
    MPH 95.26
    1000 9.603
    1/4 11.487
    MPH 119.69
    I was told to stop running after they figured out I was running consistent 11.5-11.6 (no helmet, oops!). GIAC running strong, i'm running near my LC limit so I'll have to make an appointment soon with Justin@urotuning to get my updated file flashed to raise it. Thank you Justin for making all transactions as painless, and alex@giac for answering questions promptly
    Going back Sunday for Runday Sunday, I purchased a 5 gallon can of VP MS109 and going to be doing an E85 mixed in with it. Maybe I can get into the lower 11.4x? or maybe 11.3? we will see
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Established Member Two Rings starfall's Avatar
    Dec 15 2013
    Minneapolis
    Awesome times! Do you have a gauge that shows what % ethanol you have?
    2014 Estoril Blue S5
    Instagram: Estorilblues5
    Build Thread: http://www.audizine.com/forum/showth...storil-Blue-S5
    Jan 06 2008
    Dacia Sandero
    Arizona
    Wow - really good times
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Aug 09 2015
    Sarasota, FL
    Thanks guys! I dont have an ethanol gauge, but my local pump has consistently tested at 82-85% mix in the past. However, it is something I am considering as i run this blend religiously.
    Aug 09 2015
    Sarasota, FL
    Update....
    the DA was approx 1,300 feet that Sunday I ran, so the MS109 w/ E85 didn't result in a faster time due to the heat, long lines, and higher DA's. However, when I compared my time slip to one ran in similar DA's, it was approx .1 (one tenth) faster and approx. 1.5 mph higher. I am still hopeful for that 11.3x mid-March as humidity is still low here in FL for the month and temps are cooler during evening hours (mid-high 60's), which will make for wonderful conditions.
