Try to avoid automatic c5's if at all possible. That leaves you with a 6 speed a6 or a 6 speed Allroad. As long as not driven like a hooligan, one of those will last you a long time. Just be prepared to do the valve cover gaskets and cam cap seals several times.
My last Allroad I swapped to standard a6 suspension and ended up making money on the process. Used Allroad air suspension bits are worth more than their a6 counterparts becuase there are some people out there crazy enough to want to keep the ever problematic air ride.
The only downside to buying an Allroad is the stigma that attaches to you. Allroaders are a strange people, often known to wear wool socks with sandals and eat kale. Yes..... Kale. If this sounds like you, consider an Allroad.
As for your daughter, pick her up either a b5 or b6 a4 with a 1.8t, Quattro, and a manual transmission. Cheap cars, easy to work on, and can last 200+ thousand miles easily. And most importantly, safe. Always buy your loved ones a vehicle you'd trust them getting in a serious accident with.
Oh and since your daughter sounds like she likes to work on cars, the 1.8t is highly tunable, and the b5/b6 a4's are the cheapest audis to modify, you know, should she get bit my the damn mod bug.
