Results 1 to 3 of 3
    Apr 02 2013
    above top secret
    UFO PVC how is it supposed to work?
    Guys,
    How does this valve which is located on the turbo inlet hose works? I tried to blow air from both of the ports and it went through. I thought it was faulty then bought a new one but the results is still the same. Tested with a few new units from the dealer but no difference.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    The pancake valve is supposed to let CCV gasses / pressure flow through it into the TIP, while preventing boost from entering the system when the DV opens up. I think. So you shouldn't be able to blow through the short stubby end. But if you say that even a new OEM unit let you do it then I must be wrong.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Unless you're returning the new one, I'd cut the old one open and see it for yourself.
    Chances are it's just baffled.
