Results 1 to 17 of 17
    Sep 27 2008
    Phoenix
    Not hitting full boost anymore
    Hello AZ, I have a 2007 Audi A4 Tip with a HFC, FMIC, and a JHM stage 1 tune on 91 octane, 90k miles. My car hasn't been boosting anything more than 18 pounds for a while. The car has been checked for boost leaks from a very competent shop and everything checks out. The cam follower has been changed multiple times and I am running a catch can so it's not a PCV issue. Any thoughts on what I could check next?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    The only thing i can think of is if your boost gauge is not working properly or if your wastegate actuator is not functioning properly. Check for vac leaks on the wastegate solenoid, check resistance on the solenoid, and check the wastegate adjustment nut. There is a good diy here on AZ that tells yoy how to adjust the nut as well.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    I would still check your DV personally for any rips or tears if you're running the stock one.
    B7 S-line 2.0
    Senior Member Two Rings Lockon_B7's Avatar
    Oct 17 2014
    New Jersey
    Quote Originally Posted by seandon_792 View Post
    B7 S-line 2.0
    This, if it's torn, go DV+ from GFB.
    2016 A4 auto P+ Daily driver
    2016 S3 Sepang Blue Sold
    2009 A4 2.0T, 6MT, P+, Sport Package, Meteor Grey. Sold
    2008 A4 2.0T 6MT RIP
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    Quote Originally Posted by wootwoot View Post
    What did you used to boost at?? I have everything you have minus the tip, HFC (I have a JHM test), and the fmic, and I spike at 18.8 and hold 17-17.5
    2008 A4 S-Line Grille 2.0T 6MT Quattro | JHM Stage 2 93 | Autotech HPFP Internals | JHM 3" TP | OBX 2.5" DP | JHM LWFW | RS4 Clutch Pressure Plate Combo | 034 Motor Mounts | 034 Snub | 034 Density Trans Mount | Red Top Coils | AFE Pro Dry S | CTS Silicon Turbo Hoses | ECS Intake Boot | P3Cars Boost Gauge | BSH PCV Revamp | EBC Reds | Ziza
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    Did the boost pressure change after you flashed to JHM? I spike at 18 pounds and I'm JHM stage 2. My boost pressure decreased after switching to JHM but the car got quicker. I've always thought of it as normal.
    Mar 24 2015
    Sebago, Maine
    Quote Originally Posted by AJacksA4 View Post
    Did you go from oem tune to JHM?
    Nov 26 2011
    Quote Originally Posted by Gotpsi2008 View Post
    Lol no, I went from Revo stage 1 -> JHM stage 1 -> stage 2. With Revo I spiked at 22psi
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    Same series except for revo stage 2. I spike 19-20 psi and tapper off to 15-17 with the stock diverter valve and with the gfb dv+ i spike 20-21 psi and tapper off to 16-17 psi
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    If you started boosting lower right after the tune switch I would be tempted to blame that, after all tunes are different. The one thing that I would check is actually the serp belt. I got flashed to JHM from stock and only hit 15 psi or so . after wat hing my car run I saw my tensioner moving back and forth so I replaced that and the serp belt. Took it out for a drive and hit 18 or so and after a while I was hitting peaking 22. Not sure why the serp belt would cause this but it may be an easy fix for ya!
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Rulty View Post
    That's very interesting. I may need to check my belt as I took it off to replace the thermostat and have been boosting lower (max 18 vs 21 before). I think I also read, your valve cover might have something to do with it as well.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Quote Originally Posted by Lockon_B7 View Post
    It doesn't play nice with the tune, plenty of post about it.
    What ever makes sense go with the opposite and you got it
    Nov 15 2011
    Montreal | I sell in USD
    Quote Originally Posted by Biged243 View Post
    I run it witout any issues but I did read people having some problems on Revo iirc.
    *****I sell in USD*****
    Mar 27 2013
    Vr6 gti
    Quote Originally Posted by Axis View Post
    http://www.audizine.com/forum/showth...-vs-Revision-D
    I remembered it wrong Jhm doesn't recommend it.
    Sep 27 2008
    Phoenix
    That's good information. I had lost some boost and swapped to the GFB DV+ thinking my DV might have been bad. It worked well at first but boost went from 20 to 18 peak. My shop found a small boost leak and fixed it but I still only boost 18. I may have to swap in a stock DV for the GFB and see if boost returns. It may explain my poor gas mileage as well, 20mpg the past 6 months.
    - - - Updated - - -
    Quote Originally Posted by Denio24 View Post
    Its funny you mention this, I thought about adjusting the wastegate nut to see if boost would get back to normal.
    Senior Member Three Rings Jey4's Avatar
    Apr 02 2013
    West Haverstraw/NY
    I had the wastegate issue and went from 12psi to 17psi after adjusting. I'm on the Apr tune and I've read I should be spiking at 20. Weird is I don't spike, I hit 17psi and it just stays steady there with no spike. Makes me wonder if something is still not right.
    Sent from my Nexus 6 using Tapatalk
    -Jey
    Sep 27 2008
    Phoenix
    Ordered a rev D DV. I'll install it this week and see if my boost returns, if not I may start looking at the wastegate adjustment.
