Thread: Sunroof
    Established Member Two Rings Rkost's Avatar
    May 28 2015
    Arizona
    Sunroof
    I started to notice a bit of a squeal from my sunroof and slight stutter as it opens and closes. Can I just grease the rails? Any one else run into this?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    You can use this to lube the rails per a DIY.
    https://www.europaparts.com/sunroof-...FQmSaQodcGoPcA
    A couple of questions however, how many miles are on your car and do you service your car at the dealer? I believe the lubrication is part of the schedule services at the dealer; at least the major intervals.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    May 28 2015
    Arizona
    You know, I just did the 75k on my 3.2L and I honestly don't think they did anything other than change the oil. I called and asked my advisor for service form saying they did the service and what was done. He told me there just not much done at this milage and everything "checked out". Sounded like BS
    May 28 2015
    Arizona
    Quote Originally Posted by bakedziti View Post
    Thanks for the link man!
    Jun 05 2015
    Boston
    Had same issue on 2015 SQ5 with 27k. Started squeaking and mailing noises . End up being warranty repair .
