Results 1 to 4 of 4
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    How to check number of satellite?
    How to check number of satellite on MMI 3G+? Sometimes GPS takes too long to locate, and I would like to know the current satellite number, thanks!
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Go to Route and then select the first entry in the list which is your current position. On the next screen if you scroll to the top you see the number of satellites.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jan 07 2013
    BTW, you probably need your MMI head unit replaced (5F module). This is a known hardware flaw that cause it to not acquire any satellites when emerging from underground structures for example. Audi redesigned the hardware to fix the issue. I had the problem in my RS5 and they replaced the 5F a little over a year ago. It's been fine since then.
    Jan 09 2016
    Quote Originally Posted by superswiss View Post
    Thanks for the info! Really appreciate it!
    2021 BMW 540i
