    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Raxles product question
    Hey guys, for those of you that've purchased their rebuilt b7 drive axles, what are your thoughts on quality? Have any of you looked beneath the boots at either CV ends and noticed any difference from OE? Any noticeable slop in the inner CV more or less? I'm aware their cust. service is great. Any other mentions or issues will help.
    Know that this would apply to a few of you. Thanks for responses.
    Oct 16 2008
    South Florida - Ft Lauderdale
    Best support from Marty and never had any issues. Mare sure the core returned are OEM
    Phil
    Mar 19 2014
    Thanks Phil. If I do go with raxles I can see myself cutting the boots off and reinstalling just to see if the quality of the internals are comparable to oe.
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    When I was looking at them I found that they only upgrade the CV joint and I was snapping the shafts so I looked at The Driveshaft Shop but it was around 2k for a full set.
    Edit: The Driveshaft Shop upgrades the shaft and CV joint
    Mar 19 2014
    So a an entirely different drive axle. I didn't see anything for the b7.
