Results 1 to 19 of 19
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    Anyone use a Fumoto oil drain plug before?
    I was looking at some stuff for my Subaru Outback and people were raving about this Fumoto oil drain plug, looks like they make it for the Audi, anyone use these?
    http://www.fumotousa.com/results.php...tro+1.8L+4+cyl.
    they say not to use the model with the nipple on low ground clearance vehicles.
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I've used them in the past with very good success. Aside from filter changes, a complete oil change was virtually mess free. Purchase the most "shallow" or shot plug you can get. Personally, I moved away from under the vehicle changes and now use an extractor since my filters reside on top of the motor (2015 AR).
    Veteran Member Three Rings achb5's Avatar
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    Use one on my B5 S4, love it!
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    I was just looking at these the other day. They were not made by Fumoto though. I think I will pick one up on my next oil change.
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    I used one on a friends 2015 STI. It worked so well I bought one for my R32. Havent done it on the a4 yet though.
    Apr 10 2012
    Fort Worth,TX
    I was just curious about if it fit into the A4 drain pan ok with its orientation.
    Aug 27 2013
    Philly
    Quote Originally Posted by daverdfw View Post
    Get the one with the barb so you can just stick a hose on it and directly transfer your oil to your disposal container. I want one for my 3.0, I just have been putting it off.
    Senior Member Three Rings diuvic's Avatar
    Feb 15 2012
    Indiana
    I have bad news to tell you. Or at least my experience. I was super excited to get one of these and shelled out around $30 to get one. Unfortunately, (right before my first damn oil change with this thing installed) I ran over a dead carcass in the road. It happened so fast that I couldn't make it out but I think it was a deer.
    My car "jumped" up a bit then started to make a funny noise. When I got home the fumoto was leaking oil. I still have it but I never went back to see if the actual valve was broken. My oil pan is fine but I only used the regular drain bolts or whatever you call them. I might have to do some tests to see if I can still use it. It might just need a new gasket.
    Aug 27 2013
    Philly
    Quote Originally Posted by diuvic View Post
    I mean, they do hang off, but you're not supposed to be running things over lol. Do you run a belly pan or no? Did you try just re-torquing the adaptor?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Raving? Must be boring people if they get off from a drain plug lol.
    Another horror story- Guy had a quick drain plug on his semi. He drove out into a corn field to load up with corn after combining, ran over a corn stock, and the stalk flipped the valve open, draining all the oil and ruining the engine.
    I see no need to get one- it takes 10 seconds to remove a drain plug. But if I were going to get one, it would look like this: $8 on rock auto
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Apr 10 2012
    Fort Worth,TX
    Quote Originally Posted by redline380 View Post
    they sell a protective cover for the Fumoto
    http://www.amazon.com/LC-10-Lever-F-...il+drain+valve
    Apr 07 2011
    As soon as I looked at it that was the first thing that came to mind was the valve opening for some odd reason. My car ends up in deep snow quite often and I'm not sure I'd want to test my luck. Obviously it's a long shot that the valve would hit something perfectly to open it but not a chance I'm willing to take to save some oil from getting on my hand.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    So for a valve ECS charges $35 for, I still have to buy a $3.50 clip just for peace of mind? When its all said and done, I wlll have $45 dollars into a plug that will save me about 4 minutes and 17 seconds a year.
    Pass.
    2000 S4- Working?
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I have one, but I'm switching to a magnetic plug. I couldn't tighten it up all the way because if I did, the orientation would put the valve in a position I couldn't turn it. So basically I didn't have it tightened all the way and I'd see oil weeping from around the gasket when I went to change the oil. Nothing crazy,but it still annoyed me. To be honest the time/convenience savings aren't really worth it if you change your oil once or twice a year(which I do). It takes an extra minute to break out a wrench and loosen the bolt.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Feb 15 2012
    Indiana
    Quote Originally Posted by SJorge3442 View Post
    I actually don't run a belly pan or belly cover. I have a small oil leak either coming from the camshaft seals or the camshaft bolt area. It drips oil on my alternator . I won't be able to fix it until I do the timing belt service. At that point in the story, it was late at night and I didn't want to deal with it. I just found an old drain plug from my previous oil change and popped it in. No more leaks. I actually found the Fumoto valve a couple of weeks ago and decided I should buy a new gasket and see if I can still use it. I'll pop the oil drain bolt and pop the fumoto in real quick. If it doesn't leak, I'll replace the oil and use the fumoto.
    Although what someone mentioned above is a real worry. They hit the oil valve in some corn field, the oil leaked out and ruined the engine. Hmm... Makes you want to think twice before trying it again. We'll see. I'm due for an oil change in about 1,500 miles. I'll keep you guys updated.
    Aug 26 2005
    Running without the lower engine bay cover is a bad idea considering the following problems that will cause.
    First, the belly pan reduces how much dirt and road spray can get into and contaminate the engine compartment, and everything mounted inside. The engine bay stays a lot cleaner with the belly pan installed.
    Fuel economy on the highway is reduced without the belly pan installed, due to the increased air turbulence flowing under the car and through the engine bay.
    The efficiency of the cooling system is compromised because the air pressure differential between the front of the car and the back side of the radiator is reduced. The air turbulence without the belly pan interferes with the smooth flow of air through the radiator.
    The same air pressure differential that allows air to flow smoothly through the radiator, also increases the effectiveness of the 1.8T charge air intercooler. Without the belly pan, the IATs will be higher, and the engine performance will be reduced.
    The engine noise blocked by the belly pan will not be contained, so the car is noisier without the belly pan installed.
    The belly pan is important and should not be thought of as an optional part.
    Vorsprung durch Technik
    Jan 06 2009
    All very good points.
    I just want to add that the belly pan also reduces/eliminates thermal shock on your oil pan and engine block when driving through a puddle or deep snow/slush.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Feb 15 2012
    Indiana
    Alright Diagnosticator, I'll see if I can pop on my belly pan tomorrow. I'm still leaking oil though. Now that I think about it, I haven't had my belly pan on for more than a year...
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    I have a G35 as well as my Audi. I put one of these on the G with the hose attachment. Regardless it took forever to completely drain the oil. I got rid of it....
