Results 1 to 19 of 19
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    Thread on updating to post-facelift head/tail lights?
    Has this been discussed in detail yet? I looked and found some old posts on Audiworld from Europe but that was about it. I'm curious if it is a plug and play ordeal without the "swiping" blinkers and non-LED headlights.
    Do it right, or don't bother.
    Senior Member Two Rings DB22's Avatar
    Feb 12 2014
    So Cal
    Quote Originally Posted by PKmode View Post
    The differences from pre to post facelift are cosmetic. If, however you really wanted a useful change to Matrix headlights and travelling amber rear lights then the cost would be just slightly more than a new car. Not to mention that the lights won't fit.
    2014 A6 Prestige. VCDS, Chipwerke.
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    I did some research a while back and I think I found a thread or two that some members updated their tail lights to the c7.5. It did fit our C7 and I believe required some work in vcds. But due to lack of information and crazy high cost, I couldn't justify he risk of buying them. I hope you have better luck.
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
    Senior Member Three Rings S6Express's Avatar
    Jan 14 2014
    Miami, FL
    Tail lights on the A6/S6 require body work to fill the gaps.
    2013 S6
    Ibis White / Black Int / Innovation / Bang & Olufsen / LED Headlights / Carbon Inlays / Black Headliner / Sunshades / Cold Weather
    Mods:
    HRE P47SC 21" x 9.5" Wheels / RS7 Rear Diffuser & Oval Exhaust Tips / Red Bembos / Bigger Rear Spoiler / Dead Pedal S6 Badge / Black Wrapped Grille Slats / Black Wrapped Grille Edge / Black Window Trim / K&N Drop In / Escort Max360 Hardwired w/ Remote SmartCord / VAG COM Mods / 35% Tint
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by S6Express View Post
    This.
    And the cliche applies it might be cheaper to trade in and get a face-lift model.
    Or if you were already having major rear body repair work that require replacing the tail lights and bodywork anyway.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    This is available for the A6, S6 sedan:
    Taillight Packages | A6, S6 Post-Facelift LED (Sedan)
    As mentioned the pre-facelift models will require either an upgrade to the rear post-facelift bumper or to have some custom bodywork fillers fitted.
    This is also available for the A7, S7, RS7 and requires no body work, direct swap with these kits:
    Taillight Packages | A7, S7, RS7 Post-Facelift LED
    All of the kits use the Rest of World (EU) taillights that also feature the sweeping turn signal.
    As for headlights, the differences in how these are wired up and function are numerous. A customer is working on an S6 pre-facelift to RS6 post-facelift conversion and the headlights are controlled and wired quite differently making the swap pretty involved. The shape of the headlight is also different which required the post-facelift body work.
    If anyone has more questions or needs more info don't hesitate to PM or email any time: [email protected]
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Veteran Member Three Rings Fast4DR S6's Avatar
    Aug 28 2013
    MD/DC/VA
    Sure Looks Pretty!
    2012 Golf R APR In-House Build - [U]European Car Magazine (July 2014 Feature Story)- SOLD
    2013 S6 APR/NGP Project RS6 Proto-type for all Stage 3 RS6/7 Turbos - Sold
    2019 Corvette ZR1 ZTK
    2021 Dodge Durango SRT HC
    2021 RS6 Unicorn Audi Exclusive Matte Paint
    Nov 02 2015
    Reading, Pa
    Quote Originally Posted by Fast4DR S6 View Post
    Sharp
    Mar 29 2014
    Hampshire, UK
    I put updated rear LEDs with sweep function into my (UK) 2014 C7 A7. I purchased a kit, including inner and outer rear lights and the control modules to enable the sweep function on the turn signals. The kit was pretty expensive as there are no facelift lights on the used market (that I've ever seen). There are a couple of companies offering the complete kit.
    Fitting was relatively easy, though not quite plug and play. Biggest pain was removing the interior tailgate trim to run the extra wires to the internal LEDs to enable the sweep function. The control modules connect to the outer light clusters, then you have to run additional wires to the internals. You do have to change out some of the connector pins, which is quite fiddly.
    I **think** there may be VCDS coding required to enable US vehicles to use the European tail lights correctly.
    I have a YouTube clip here:
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jan 23 2016
    chicago
    That looks really damn good 4DR!
    Sep 19 2005
    Milwaukee, WI USA
    Thanks all. Looks like I'm tinting the rears and calling it a day.
    Dec 05 2015
    Chicago, IL
    This is my approach as well. I bought the "light smoke" taillight vinyls from Headlight Armor and will be installing them tomorrow.
    Established Member Two Rings martz's Avatar
    May 01 2014
    2014 Audi RS7, 2010 Audi Q7 4.2 TDI, 2014 Ducati SF848, 2003 Nissan 350Z Roadster
    Australia
    my tail lights on RS7:
    purchased from: http://www.active-sound.eu/
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by martz View Post
    Looking awesome
    www.europrice.us
    [email protected]
    Dec 05 2015
    Chicago, IL
    Quote Originally Posted by swope View Post
    Uploaded a couple quick pics. The first pic has stock on the left and tinted on the right. The rest are all tinted. I haven't managed to get any decent pics in the sun yet, but it was at the dealership for a couple days and the weather has been gloomy here.
    Overall, I'm really satisfied with the look and the quality of the Headlight Armor product, although I got a bit of moisture trapped under the passenger side tint... we'll see if it evaporates over the next month.
    http://imgur.com/a/UhkOZ
    Mar 04 2015
    Houston, TX
    Quote Originally Posted by Alex@Europrice View Post
    Cheers,
    Can I reuse my existing C7 harness on the C7.5 tails? (s6)
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by tph4m86 View Post
    Do you have a C7 model with post-facelift taillights now? Trying to fit those taillights to a new C7.5? Just trying to get the exact order of operations in your request.
    Cheers,
    www.europrice.us
    [email protected]
    Mar 04 2015
    Houston, TX
    Cheers,
    I have a C7 and wanting to upgrade to a C7.5 bumper and tails
    Aug 07 2008
    Dallas, TX
    Your factory wiring will not work with the C7.5 taillights. That is what the upgrade package is for and includes: wiring and parts to adapt your factory wiring to the facelift taillights plus it comes with the modules to output the sweeping signal to the taillights.
    You would want to order the whole upgrade and select North American Pre-Facelift as your year and region, then LED as your current taillights. That would get you the proper parts to upgrade and have the sweeping turn signals.
    As for the rear bumper, if you were interested I can quote that out via PM or email, please let me know the model you have now and what rear bumper you would like: [email protected]
    Cheers,
    www.europrice.us
    [email protected]
