Results 1 to 4 of 4
Thread: Better Brakes
    Established Member Two Rings q7newbie's Avatar
    May 20 2015
    2012 Audi A7 S-Line Black Edition, 2012 Yamaha R1
    Glasgow
    Better Brakes
    Just a quick question. After having my current q7 for close to 18months now, and having changed the brakes once on its service, I'm still not totally happy with the stopping power of them.
    Is there a way I can have them altered to have more "bite"? And if not, can anyone recommend a way for me to upgrade them? If so, what would/could I upgrade them to? (NOT Carbon Ceramics!)
    What does a brake upgrade involve cost and time wise?
    Thanks.
    Sent from my SM-N910F using Tapatalk
    2014 Audi Q7 TDI S-Line Premium Plus
    Black Edition
    LED Engine Bay Illumination Pack
    Front + Rear Cameras, Lane Departure Monitor, Blind Spot Monitor
    MMI High- Plus Google, TV Tuner
    Full Panoramic Sunroof, Heated Steering Wheel + Heated Seats (front and back)
    Smart Key + Full Memory Package
    Some will love you, some will loathe you. But let all with integrity respect you...
    In, Out and Around...
    better pads but they will dust more and be much louder.
    Veteran Member Three Rings zerokiller698's Avatar
    Nov 11 2011
    NKY
    EBC Redstuff pads are a very low dusting pad that will be an upgrade over stock. Pair that with EBC or StopTech replacement dimpled and slotted rotors or just slotting rotors that will give you a much needed upgraded over stock.
    EBC Yellowstuff pads are a bit longer lasting and provide a better cold and hot bite over Redstuff, but you get a very high dusting pad that will eat rotors at a higher rate.
    Hawk HPS pads will perform like EBC Redstuff but with a very high dust rate.
    Hawk HPS 5.0 pads are a slight bit better than the regular HPS and dust a lot less. But still do not perform as good as the EBC Yellowstuff.
    I personally run EBC Redstuff on everything I've owned over the past 8 years. They are not a "track" pad yet I have tracked my old S4 with them and they stood up to extreme abuse and kept going.
    Current: 07' Q7, B6 S4
    Past: B5 1.8t, B6 S4, MK2 VR6
    Instagram: Zerokiller698
    Senior Member Three Rings DEEZ's Avatar
    Dec 11 2008
    Utah
    I did custom adams slotted rotors paired with Pagid Pads front and rear and it made all the difference in the world.
    11' S4 Ibis White | Prestige | DSG | APR Stage II+ V3.0 | APR DSG Tune | Stage II APR Carbonio Intake | AWE Exhaust w/Diamond Black Tips | Deval Diffuser | JHM Slotted Rotors F&R | 20x10 ET35 AG M590 | H&R Coilovers | Eurocode Adjustable Rear Sway | RS4 Grill
    18' Q7 Glacier White | S-Line | Prestige | Black Optics | Adaptive Air | Adaptive Cruise | Thule Aeroblade
