Results 1 to 7 of 7
    Active Member One Ring Black Fox's Avatar
    Dec 22 2014
    2009 Ford F-150 Platinum, 2004 Harley Davidson 1200C Sportster
    Savannah, GA
    Motor Mounts need replaced?
    On a scale from 1 to 10, how bad do my motor mounts needs replaced? Or is the purple stuff enough to tell if they need replaced or not? Is it worth replacing with the Febi B5 S4 mounts?
    Thanks guys.
    [IMG][/IMG]
    [IMG][/IMG]
    Senior Member Three Rings Arnie91's Avatar
    Oct 28 2015
    London
    Looks like your mounts are leaking
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    I'm not an expert here, but if they were never replaced, do it. I recently replaced mine with heavy duty mounts from Passat.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    If they are leaking the purple fluid that is inside them, they need replaced. How badly they need replaced would depend on how good or bad the rubber around them looks. It's hard to tell with the images posted, but I would at least plan to replace them at the next service interval.
    Dec 22 2014
    Savannah, GA
    ok thanks. I'll take a look at the rubber like you said. I just rolled over 100k miles, so my next service is due pretty much right now. I think I'll go with the S4 mounts though.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Just replace them now, it can be a harder job later if the mounts become completely destroyed. I recommend removing the nut and cutting the stud off the old ones to make removal easier. I'd also recommend cutting some length off the stud on the new mounts to make install easier.
    Senior Member Two Rings mprivi's Avatar
    May 26 2015
    2002 B6 A4 3.0 Project
    Long Island, NY
    Quote Originally Posted by MacFady View Post
    Its it easier to remove the brackets or cut the bolt down and jack the engine up a little? Going to be doing this on my 3.0 as soon as it warms up.
