Originally Posted by
jmcS4
they often get spider web looking cracks in them. you could also look under the reservoir and look for dried coolant on the valve cover, it'll be white water spots.
It has some white sports over the valve cover, cleaned it up after the radiator work and didn't see anymore.
Brandywine050
You may also want to try and get someone to put a coolant pressure tester on to see if you can source the leak before you spend any more money.
Shop did a pressure test before replacement and only found tiny leak on the top of the radiator passenger side ( the white spots over there), they said i can keep checking and add the coolant until it went bad. But I decided to replace it (also lower & upper hose, Serpentine Belt, tensioner, ATF flush), seem didn't fixed the whole issue.
badger.
Mine is currently leaking from the rear coolant temp sensor buried between then firewall and motor. Fairly impossible to actually see it without removing some hoses and whatnot but I know it is from there because that little u-clip retainer got busted reinstalling the motor and it was ziptied. However I have a drip visible on the ground.
Impressive you can lose 1/3 tank in 400miles and not see anything on the ground. What does your oil look like?
Right now, the coolant level is at middle of min and bottom, guess 2/3(of reservoir) coolant gone already. it's the Pink/Red Audi G13. I only drive it once a week and i didnt notice any leak on the ground. I feel like the coolant leak/gone while driving it (is it possible?) but ive no idea at all, i don't have much knowledge about cars.
Thanks
