Results 1 to 37 of 37
    Apr 16 2010
    BC
    Audi’s quattro shows not all AWD systems are alike
    Read this today about the next generation Quattro.
    http://driving.ca/audi/a4/auto-news/...s-are-the-same
    Oct 28 2009
    Northampton, MA
    What a downgrade. It doesn't even have a center diff, just an engage/disengage clutch. i.e. not real "Quattro". This is the kind of part-time AWD featured on regular 2WD cars so they don't get stuck in snow, not for handling benefits or performance purposes, the sort of AWD system we Audi/Subaru folks have been knocking for years on other makes about how inferior it is. I don't buy the new "next generation" marketing, it's cost cutting and fuel economy all the way.
    May 21 2015
    Burlington . CANADA
    +1^
    '15 Q5 TDI
    Technik
    S-Line/Monsoon/Blk Opt/B&O/KW V2/pano roof/H&R spaced/sq521"conti wrapped
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Quattro has be the Real MVP for a very long time, I think they know what they are doing. I do somewhat question this though.
    Junior Member Two Rings Blythiano's Avatar
    Sep 24 2014
    Portland, OR
    Quote Originally Posted by smonska View Post
    Hopefully it is sort of the reverse of this and errs on the side of being engaged normal quattro style. Then, it just has the ability to disengage for fuel economy if you're just cruise controlling on a straight highway.
    Interesting that article says it will be introduced in the A4 Allroad but was only in the sedan as a test setup.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I'm not a fan. With city driving, etc., I feel like there will be a lot of time in FWD, eating front tires and making it so I have more sensors to worry about.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Mar 01 2006
    Kitchener, ON
    I kind of agree, and would prefer a more mechanically based AWD system vs using electronic clutches.
    The kind of part, is just how 'proactive' is the system. In the end, I agree, the consistency of the mechanical diff's are usually better then electronic clutches that are programmed to open and close because at times you can 'over engineer' the program vs mechanical you can likely get more consistent results - with the exception of weather / road conditions.
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Sep 24 2014
    Portland, OR
    Saw this Audi video on the technology...
    https://youtu.be/VjwYNvsJ-OM
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by Blythiano View Post
    Actually was thinking about this morning. The idea isn't half bad...
    Example, in Comfort (or rename to Eco) or Auto mode, if you had this technology in place, this is excellent. Cruising the highway you put it in Eco mode and save gas. If you have Dynamic (Sport) mode, you have it locked just like we always have known it to be and have fun on the track or in poor weather conditions.
    Auto mode is where Audi can play with the technology to get it to play nice in both situations.
    Past
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    Agreed. Engineering is now implemented, as you note, with two objectives in mind: cost cutting and fuel economy.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Oct 28 2009
    Northampton, MA
    Hopefully this only shows up on low-performance economy-minded models, i.e. sub 2.0L 4 cyls.
    Mar 17 2014
    Los Angeles, CA
    I REALLY hope this doesn't make it into the S models. Because nothing screams performance like "FWD masked as AWD"
    instagram
    Veteran Member Three Rings Killerboots's Avatar
    Nov 19 2014
    Phoenixville, PA
    Interesting thread, subscribed. I agree with everything being said so far. We'll see if the marketing is real or not soon enough.
    Veteran Member Four Rings hodrosS42001's Avatar
    Mar 18 2012
    New Jersey
    You all realize that this is nothing new.. The A1, TT, TTS, TTRS, A3, S3, RS3 and R8 all use a Haldex based AWD system. I'm sure I even forgot a car or two.
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by hodrosS42001 View Post
    And I don't have a Haldex based system and do not want one. And to compare the R8 system to this is like comparing apples to oranges, as the R8 is primarily RWD, as opposed to FWD as described here.
    instagram
    Jul 10 2012
    buffalo
    the taurus SHO has been using a varient of the proposed system for years and it handles serious power. It is not fair to compare the 2 systems. different brands, goals, price point, and power. There are a couple guys making north of 600whp and running some nasty 1/4 mile times and it seems to work really well for them. This system launched in 2010.
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Oct 28 2009
    Northampton, MA
    That video shows why I don't want it, front wheels spin, then rears kick in. However quickly, it's still AFTER slippage occurs, it meaning it isn't dynamically giving power to the rear wheels, as an assist to cornering, let alone a rear bias, like Quattro (especiialy with sport differential) or the system in a WRX or Evo. It's a "if it's slipping only" system. It's going to handle like a FWD car, because it is a FWD until you slip. While I'm no x-drive fan, as it is still a clutch type system, even that is at least RWD biased.
    Jul 10 2012
    buffalo
    the engagement is all in programming. It is purely speculation on how audi would implement this. Who knows it could always be engaged until a given tq request above a certain speed is achieved then it releases the rear wheels to improve economy. I get what you are saying and I don't completely disagree. I feel that audi will implement this system in a more effective way than what the above video shows.
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Jan 11 2014
    So will the new S4 have this shity new Quattro?
    "The Pedal Response Kanye West" using Tapatalk
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    I think we can only speculate if cost cutting is a concern, but there is a push for new legislation (some legislation implemented) that requires auto makers to improve their average mpg. The S models, executive cars, and R8 don't help that average, this is probably one way Audi will get close/r to compliance. It will be interesting to see if they use this system on the higher end models.
    Also whoever brought up the uneven wear good point. I wonder what the consequences would be.
    Sent from my E6653 using Tapatalk
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    May 21 2015
    Burlington . CANADA
    cool slo mo video
    '15 Q5 TDI
    Technik
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    The TT and A3 platform cars all have understeer issues due to only being able to transfer 50% of power to the rear in any real-world conditions. The real question with this new system will be how much power is able to be transferred rearward. I understand this is not a Haldex system but an in house development.
    Quote Originally Posted by RudyH View Post
    I prefer mechanical quattro as well and hate the idea of a car being FWD much of the time; but theoretically speaking, if this new system can be made to send 75-85% of torque to the rear, it will eliminate everyone's complaints in actual real world driving.
    These latest systems are quite amazing in their ability to react before any loss of traction is realized. They use throttle position, yaw sensor, RPM, wheel speed sensors, etc... to truly react in a proactive fashion.
    Quote Originally Posted by jmeenach View Post
    That's what I read in a few articles. No performance models in the plans.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by LINDW4LL View Post
    Then I might not care. S4 still in my sights
    instagram
    May 11 2009
    IL
    Hi all,
    sorry if I missed it being blatantly stated, but does the 2017 A4 use the "old" system, or this new next-gen Quattro? I see the original article specified "A4 Allroad" but then described a 2017 sedan as their test mule. So I just want to be 100% sure the normal 2-17 sedan in production still uses the normal system? I am 95% sure I am pulling the trigger on a 2017 Prestige this spring, so want to be sure. Thanks!
    Brian
    Dec 10 2011
    CLT | MKE
    The B9/2017 A4 uses normal mechanical Crown diff quattro.
    -Hayden
    Mar 20 2011
    Russia / St.Petersburg
    Is it an official information or just your guess?
    Veteran Member Three Rings ryan_sn's Avatar
    Jun 01 2008
    2016 Audi S3 Daytona Grey
    Ontario, Canada
    Here is a slow mo video of the Haldex system on my S3 that my cousin took. Video quality isn't the best but its watchable. I also have no idea if this was the launch with or without TCS activated since I did one with traction control on and off.
    2007 Audi A4 2.0TQ Quartz Grey
    2012 A4 Quattro 2.0TQ Monsoon Grey
    Present:
    Future:
    2023 BMW M3 Competition xDrive - Toronto Red
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by Treiber View Post
    That is a fact.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Established Member Two Rings CVTwhatadumidea's Avatar
    Jul 16 2008
    2010 MB C300 4Matic Sport
    Fort Wayne
    The R8 uses a viscous coupling.
    QGM '08 B7 2.0T 6MT Premium+ | APR Stage 2+ | Podi Mechanical Boost Gauge | RAI HFC/DP combo | APR HPFP | ECS snub mount | JHM chromoly lwfw and RS4 clutch | LaPower Bluetooth Module | Black Headliner Conversion | Pipercross Dry filter | R8 Coils | GFB DV+ |
    Jun 23 2013
    PacNW
    If you followed the crown gear quattro implementation, it already uses wet clutch plates as part of what controls torque splitting. The tech video for the crown gear diff states that electronic control of these plates can be added allowing 100% torque transfer rather than 85%.
    https://youtu.be/_09y0SwOrkA?t=3m37s
    100% means you're disengaging the other axle, which is what the newest system is claiming to do.
    It's not clear if they're doing it directly in the clutch plate of a crown diff or adding a clutch plate to a separate center diff.
    In any case, based on the description what separates this from Haldex is that the center diff itself will be fully mechanical when engaged.
    If you left the diff permanently engaged (Say be enabling sport mode? speculation of course..) it would react instantly just like the current system.
    Time will tell how the system performs but I don't think Audi would jeopordize it's signature quattro brand with anything sub-par.
    May 21 2010
    Quote Originally Posted by skis4hire View Post
    I agree 100%. Doesnt make sense for them to go backwards.
    Senior Member Three Rings 15DGR V6's Avatar
    Jan 09 2009
    2018 Audi TTRS
    Cleona, PA
    The way I read it, there are two additional clutches, in addition to the existing CGD, to completely disengage the driveshaft and separate the front axle from the rear axle. The clutches simply engage/disengage Audi's existing mechanical Quattro system.
    Senior Member Two Rings dbuxton13's Avatar
    Apr 20 2016
    Germany
    I asked all the above type of questions while at the Frankfurt Auto Show in Germany where they debuted the new S4 and the A4 Ultra. The Ultra is a specific type of A4, which for now is Europe-only. The Quattro on the A4/S4 do not use this Ultra system.
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    I could be wrong but I was told that on the B9 A4 it was the TorSen type center diff (not crown type) and that the "Ultra" type Quattro system would be introduced on the new B9 Allroad.
    Jan 09 2009
    2018 Audi TTRS
    Cleona, PA
    Quote Originally Posted by Jet Jockey View Post
    That's what is stated in this article:
    http://blogs.youwheel.com/2015/06/29...-a4-announced/
    Although, I'm not sure that Audi has given up on the Crown Gear Differential as of yet. So far, it's only been used in certain vehicles and they've all been S/RS cars. So, perhaps, it will remain but only for use in S/RS cars.
    Apr 20 2016
    Germany
    With regard to the new Torsen type C (or T-3) differential being used in the B9 A4... all the information you can handle, and didn't ask for!:
    http://torsen.info/products/T-3.htm
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by 15DGR V6 View Post
    That is my understanding that the S and RS cars will have the Crown Gear diff.
