Results 1 to 7 of 7
    May 29 2015
    Calgary, Canada
    Used exhaust question, should I be concerned ??
    Picked up a used APR RSC exhaust ... and found these at the bottom of the two rear mufflers.
    I don't understand why there would be two pinholes at the seam like that. Obviously they've been there for quite some time. Should I get them closed up?
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    They are weep holes from the factory. Do not block them- they are intended to let condensation drain out.
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Quote Originally Posted by MerkurRS View Post
    This. Just make sure the seam itself hasn't cracked. The pinholes are fine though.
    May 29 2015
    Calgary, Canada
    That makes sense....never actually seen them on any other system I've owned.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    This, Every muffler ever built factory and aftermarket usually has these. Prevents water from accumulating inside of the muffler.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    ^^ this... & the black is from dirty soot water dripping out and spraying up on the exhaust. It's normal...
    Oct 06 2014
    Cleveland, OH
    What they said. I just sold my APR exhaust and noticed the same thing as I was packing it up. Tried to reach APR but was unsuccessful, so I asked a local muffler shop. Put my mind at ease.
