Results 1 to 6 of 6
    Registered Member One Ring ic3m4n7's Avatar
    Oct 30 2015
    Florida
    Brakes Randomly Getting Stuck?
    So my '03 A4 recently started acting up. Brakes are sticking after having the pedal depressed. Getting a load squeaking then rasping noise upon stopping. I'll be taking the calipers off tomorrow and taking a look but I figured I'd see if anyone has had this problem. I found a thread with a somewhat similar discussion but their problem started after having replaced some brake parts. Only thing that was different was that I removed all the wheels to refinish them; and then after they were installed again, the devils war-cry started. =( Any help is greatly appreciated. Thanks
    *2003 Audi A4 1.8T Quattro Avant (19" wheels if it's of any help)
    Aug 26 2005
    Front, rear or both?
    Vorsprung durch Technik
    Oct 30 2015
    Florida
    I'm only hearing/feeling the front as of now. They'll sometimes disengage independently of each other (the left/right brake will release after letting off the pedal, and then the other side follows)
    Aug 26 2005
    Do you know when the brake fluid was flushed last time?
    Either the caliper pistons are sticking or the caliper guide pins are sticking.
    Oct 30 2015
    Florida
    I just bought it a couple months ago and I've been updating it little by little so I'm not sure if or when the previous owner did it.
    AKA: grease or polishing?
    Aug 26 2005
    Quote Originally Posted by ic3m4n7 View Post
    I suspect the calipers need to be disassembled and the pistons and cylinders cleaned of any corrosion due to water in the brake fluid. If the corrosion is bad enough, replace the calipers.
