Results 1 to 10 of 10
    Active Member Two Rings eclipseballer's Avatar
    Apr 19 2015
    Massachusetts
    Do the pad sensors have a reset function?
    Hey all,
    Driving along today, Orange brake light, red BRAKE, and "Brake Pad Warning" come on. Stayed during a couple of driving cycles and it isn't registering on my scan tool to delete.
    Interestingly enough, I did the pads and rotors all around only 2k miles ago. Pads still look great up front (where the sensors are). Was I supposed to reset these sensors somehow? Can I clear this with my VAG-COM?
    Thanks in advance!
    Sent from my Nexus 6 using Audizine mobile app
    BLACK 2012 Audi S4
    Premium+/6MT/Sport Diff
    Previous:
    2002 BMW M3 Coupe 6MT: Carbon Black Metallic, Android Dynavin h/u, short shifter, rearview camera, custom exhaust (TOTALED RIP )
    2012 Jeep Wrangler Unlimited Sahara 6MT: Deep cherry red, TeraFlex 2.5" lift, 35" Nitto Mud Grapplers, Smittybilt rock rails, Bestop Trektop, Currie HD steering setup (SOLD)
    2010 Chevy Suburban LTZ 2500: Navy blue, fully loaded (SOLD)
    Mar 21 2015
    Did you install a new wear sensor or use the old one? I don't think you can reset a senor.
    Apr 19 2015
    Massachusetts
    Local mechanic did the job, I suspect he skipped out on replacing the sensors. Can I replace them independent of the pads, or do I need to buy new pads again?
    BLACK 2012 Audi S4
    Previous:
    Mar 21 2015
    Quote Originally Posted by eclipseballer View Post
    You can buy it here. It's pretty easy to replace.
    https://www.ecstuning.com/Audi-B8_S4...ads/ES2089623/
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    If I replace the brakes before the sensor goes off do I still need to buy a new one?
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Mar 21 2015
    Quote Originally Posted by B8 S4 View Post
    I would replace the sensor when you replace the pads.
    Mar 12 2014
    Long Island, NY
    The sensor only has to be replaced if it is broken, when the sensor is broken is when your light comes on.
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by Szemenyei View Post
    Exactly. Most new sets come with a replacement but if your didn't go off you can reuse it. All it does is wear down to a certain point and complete ( or break ?) a connection triggering the warning light.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Mar 21 2015
    Quote Originally Posted by sacandagaD View Post
    I replaced mine because my brakes came with a brand new one. Why wouldn't you replace in that case. Who knows if his tech didn't damage his.
    Jul 02 2013
    Totally agree, no reason not to if you get a new one with the pads, but if they didn't and it didn't go off yet, it probably wouldn't be end of the world. If you did damage it to the point it didn't work by breaking the wires, it would probably go off, unless they touch each other.
