Results 1 to 14 of 14
    Veteran Member Three Rings Diamond Dog's Avatar
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Are struts covered under Audi CPO warranty?
    My S5 as at the dealer trying to uncover a rattling noise. Tech says he thinks its from the front struts. He says Audi CPO does not cover struts. Here is the CPO agreement http://microsites.audiusa.com/…/2010...nty_Brochure.… I do not see where struts are excluded. Any advice for me?
    The rattling (sounds like someone is gently and slowly crumpling an aluminum can) only occurs at low speeds. If I go faster and over bumpier roads it stops. Would this suggest that it COULD NOT be the suspension components (should get louder when its faster and bumpier)
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    your link doesn't work but I found this:
    https://www.audiusa.com/content/dam/...ty-Booklet.pdf
    Under what is covered it states:
    "Suspension - front axle sub frame, control arm supports, control arms, wheel bearing housing, steering knuckle, front wheel hub, coil springs,
    stabilizer bar, stabilizer links, rear axle beam and support, stub axles, rear bearings and housings, rear springs."
    No mention of struts :(
    Anyways as far as what the problem could be, I found this thread: http://www.audiforums.com/forum/b5-m...t-left-151865/
    People are also reporting only during slow speeds and its the upper strut mount. Maybe you can get another opinion from another dealer?
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Mar 02 2009
    State of Confusion
    I only found 2012 and struts are not covered
    I'd get koni yellows or bilsteins...
    Sep 05 2014
    Quote Originally Posted by mjfloyd1 View Post
    2nd on Bilsteins!
    Ken
    2021 Q5e Prestige
    District Green
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Quote Originally Posted by Sweep View Post
    Thanks for this. So if struts are not covered, strut mounts probably will not be covered ?
    Mar 02 2009
    State of Confusion
    It doesn't list strut mounts either so they are not covered
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    when you buy coil over kits, do they typically come with improved strut mounts? If not, who makes aftermarket ones?
    Senior Member Three Rings Ryan_qttro's Avatar
    Oct 17 2011
    2005 2.7T Allroad
    Baton Rouge, Louisiana
    There is a TSB about the outside brake caliper spring making noises when going over bumps, you can brake when hitting the bump and noise go away. Of course car is at dealer now, hopefully they figure it out. The sound sounds similar to the sound you are describing.
    05 2.7T Allroad
    Audi Tech
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by Diamond Dog View Post
    Ask the dealer to show you in writing where it says that it isn't covered.
    Under the "What IS covered" part of the CPO it says: "This list is not inclusive. See your Audi service representative for specific items."
    Under the "What is NOT covered" part it does not specifically list struts as being excluded from coverage.
    So it looks like there are two possible outcomes we can take from that:
    1) The dealer holds the complete list of items that are covered under CPO, and should be able to provide it for you.
    2) There is no complete list of what is covered and it is up to the dealer to decide if they want to or not.
    Let us know how it goes but I would make the dealer give you more information on why they claim its not covered.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Oct 17 2011
    2005 2.7T Allroad
    There is a complete list, the shocks are not on it.
    05 2.7T Allroad
    Audi Tech
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by Ryan_qttro View Post
    I see you have audi tech in your sig. Can you provide that list for us? Im CPO as well and would love to know exactly what is and what isn't covered.
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    I found out I have Audi Protection Plus Platinum which covers the car for 8 years. Under the "silver" category it covers struts. Platinum covers everything in "Silver." I will try t his route now
    Oct 17 2011
    2005 2.7T Allroad
    Quote Originally Posted by DannyDeez View Post
    It's 22 pages, not sure how I could get it to you exactly.
    05 2.7T Allroad
    Audi Tech
    Sep 11 2004
    16 Q5
    Westchester, NY
    Yikes I didn't think it was that much. If anyone knows of a pdf version online, that would be great. Im going to ask my dealer once I finally get around to going there. Im assuming they'll have no trouble providing it for me?
