Results 1 to 22 of 22
    Oct 22 2012
    Markham
    Rebuild at 78k km? - Zero oil pressure at ide
    Made a thread on this issue a while ago but things seemed to have taken a turn. Got the low oil pressure light on my 2012 A4 a couple weeks ago and had it towed to the mechanic. He replaced the oil control valve and the light went away. Two days later it came back. Now he's further replaced the oil pump and pressure still drops to 0psi (starts out high 20s then drops to 0). Now we're out of ideas and thinking of a rebuild... Seems unusual for a car with such low KM? Car has always been maintained on schedule. Any ideas would be appreciated.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    You want to talk to audi of america about the issue they might help
    Oct 22 2012
    Markham
    I would but my car is Revo tuned. mechanic will be replacing balance shaft tomorrow. hopefully that does it
    Oct 27 2014
    Does not matter of the tune. You should know the dealership that is cool with tune. I had my stage 2 piston job done for free at 108k with the tune. Aoa paid for it. Anyways good luck
    Oct 22 2012
    Markham
    stage 2 piston is for oil
    consumption and there is an extended warranty on that though. I'm out of warranty... thanks for suggestion though!
    Oct 22 2012
    Markham
    mechanic thinks it's part of the balance shaft
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Does your mechanic believe oil volume is being lost at the balance shaft's bearing and that is what is causing your low oil pressure symptom?
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    May 07 2014
    Who's your mechanic? I'll be in the Markham area shortly myself, need a good one :)
    2010 A4 2.0t quattro 6mt
    Oct 22 2012
    Markham
    no, we literally have no idea... here are the specifics...
    -Car has 77k and just got a Revo tune last month
    -Drives 100% fine, but when idling for long periods of time, pressure creeps down to 0 psi, as assessed by an analog gauge
    -No filings in oil pan, no sludge, pickup screen is clean, etc
    -Replaced oil control valve and oil pump
    -Did an oil and filter change
    -Car doesnt really burn oil, maybe 1L every 5k which seems common/normal in these cars.
    He is still in the process of checking the balance shaft (as pictured above), he has heard that this has been the problem in a few rare cases on these engines. If that turns out the be not the problem, the engine will be getting rebuilt.
    I would assume I would hear knocking or vibrations if the bearings are worn but none of that....
    I did hear some people say the PCV was the cause of their oil pressure but that doesnt make much sense to me.. maybe ill try it as a last ditch attempt. Thanks for the responses guys, any other suggestions would be appreciated!
    Oct 22 2012
    Markham
    PM'd.
    Any possibility of this being an electrical gremlin? Checked all the wiring and they visually appear to be fine, but am at a total loss for how this can happen mechanically without any knocking.. Dont want to tear the engine down only to find that nothing was wrong with it.
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    Try a mechanical guage to verify the actual pressure?
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Oct 22 2012
    Markham
    Quote Originally Posted by NLPed68 View Post
    Yep, have been having one. Pressure drops to 0psi at warm idle
    Jun 12 2013
    Where do you have the mechanical gauge installed at?
    Build Thread
    Oct 22 2012
    Markham
    my understanding is that there is only one mounting point for this generation of engine, near the oil cap?
    Jun 12 2013
    you pulled out the stock sensor then?
    Oct 22 2012
    Markham
    yes, is there anywhere else I can check pressure?
    Jun 12 2013
    Has this been checked / verified: Oil Pressure Regulation Valve (N428)
    Oct 22 2012
    Markham
    unfortunately that was the first thing we replaced and no dice :/ hopefully the balance shaft is found to be the culprit
    Jun 12 2013
    Here are the other areas I'd check too:
    - Valve uni to the oil filter
    - Oil cooler
    - Both pressure switches around the oil filter:
    * Oil Pressure Switch (F22)
    * Reduced Oil Pressure Switch (F378)
    Jun 12 2013
    F378 is the one to remove to verify oil pressure mechanically. Here are the oil pressure's you should be seeing:
    ¤ Oil pressure when the vehicle is idling: 1.2 to 2.0 bar (17.4 to 29 psi)
    ¤ Oil pressure at 2000 RPM: 1.6 to 2.2 bar (23.2 to 32 psi)
    ¤ Oil pressure at 3,700 RPM: 3 to 4 bar (43 to 58 psi)
    Oct 22 2012
    Markham
    thanks for all the help! will report back
    Jun 12 2013
    Anytime. I know motors quite well, I dont know this one internally in and out very well, but in general, if you lose oil pressure as the engine heats up that means the oil loses viscosity (which is normal) and the tolerances (some where) are not being fulfilled anymore. Usually when you spin a main bearing, this is a tell tale sign. Since you mentioned you guys didn't find any babbit material, you should be ok in that regard.
    I just don't see how a balance shaft could cause this unless the balance shaft feed/ bearing is toast. This also depends on where that feed is within the oil circuit.
