Results 1 to 7 of 7
    Senior Member Two Rings SnowBum124's Avatar
    Sep 14 2006
    1999.5 A4 1.8t avant
    seattle
    DBC 75mm Throttle Body PN#?
    I am adding a SEM manifold to my AEB setup and i wam wanting to add a 75mm TB. YES i have done some searching but i have not been able to come up with a rock solid part number for a 75mm TB. some show the VR6 as 65/70/75 or do i want a S4 tb? if anyone can help me out with my confusion that would be great.
    BetaAlphaTau member # 40
    love my shag-in wagon
    GT2871R turbo, 630cc Siemens injectors, 034 Downpipe, SPAmanifold, TR11 FMIC, Maestro7, south bend stage 4, VR6 TB
    Jan 22 2014
    Fairfield, Ca
    VR6 OBD2 TB is 70mm and what DBC use, the S4 TB is also 70mm but id DBW. The VR6 TB is thinner than the S4, so I had to us 40mm bolts vs the 50mm bolts the IE manifold came with.
    2005.5 A4 Avant; TSI cam follower conversion. Build Thread
    99.5 1.8TQM; Maestro, GTX2867R, and a ton more mods. RIP
    Build Thread
    Sep 14 2006
    seattle
    OK so the VR6 TB is a 70mm, does anyone know of a 75mm that will work?
    Jan 22 2014
    Fairfield, Ca
    I'm not going to pretend to know all things TB related, but that's an odd size, are you sure it's 75 that you're looking for? I have only heard of 70 or 80mm (hemi).
    Build Thread
    Sep 14 2006
    seattle
    Sep 14 2006
    seattle
    So is the VR6 throttle body the only upgrade options for the DBC then?
    Jan 22 2014
    Fairfield, Ca
    As far as I know.
    Build Thread
