Results 1 to 13 of 13
    Senior Member Two Rings shayan_a4's Avatar
    Jul 12 2014
    2014 VW GTI and 2014 mercedes SL550 2014 b8.5 audi a4, c7 A6
    woodland hills
    how hard is it to change the injectors?
    so like the title of the thread says, how hard is it to change the injectors on our cars?
    Jul 12 2014
    woodland hills
    okay thank you, but is it the same steps if i have the silver intake manifold? because my PCV system looks different than in those pictures?
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I just found out the warranty on my injectors was extended to 10 years or 120,000 miles.
    My 2009 A4 Prem+ Build thread
    Jul 12 2014
    woodland hills
    Quote Originally Posted by Lambda13 View Post
    yes, i should be under warranty too, but im tuned and all of that good stuff so im kind of skeptical on taking my car to the dealership
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by shayan_a4 View Post
    flash back to stock? what's the difference if you get TD1'ed lol
    I have a replaced ECU so the flash counter won't even work for them as an excuse. If I go back I'm flashing to stock and having them look at whatever needs fixing... Probably won't ever do that but still.
    Jul 12 2014
    woodland hills
    yea im really contemplating flashing it back to stock
    Jul 07 2012
    Boston, MA
    I added some more lol.
    But yea I mean I don't see why getting a TD1 flag is a big deal if you're tuned and plan to always be tuned through the end of your warranty. Worst case flash to stock and try, the only thing you'll lose is like a day where they TD1 you and you're in the same spot ya know?
    Jul 12 2014
    woodland hills
    yea that makes sense, but i wonder how much the stealership would charge to do this lol
    Jul 07 2012
    Boston, MA
    Warranty... may waive the deductible but if not its $85. I've got a new(ish... compared to the car anyway) intake manifold, exhaust seals and a few other randoms parts they have needed to replace along the way.
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    If you have the metal intake manifold instead of the plastic, it's quite a bit different fueling wise and half of the DIY above doesn't really apply.
    I've pulled the injectors on my A4 w/metal intake manifold 3 times now. I'll try to grab some pics later for a few tips.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Jul 12 2014
    woodland hills
    oh okay, thanks for helping me out guys
    Aug 29 2014
    I wasn't able to grab any good pics that showed anything without taking it all apart, so Ill try to list the tips.
    1. I was unable to get the two rubber hoses on top of the intake manifold off the barbs, so I just didn't bother with them and set the intake manifold on top of the engine with the hoses still attached.
    2. There is a metal arm supporting the intake manifold, this needs to be unbolted. Removing the throttle body makes this a whole lot easier.
    3. There is a metal tube coming from the bottom of the high pressure fuel pump at the back of the engine to the fuel rail. Both ends need to be undone. I just broke the seal to bleed off excess pressure and put some rags down to catch the gas.
    This is what my engine bay looked like while working, a little cluttered, but I didn't have to undo any hoses except the hard fuel line, pre-throttle body intake hose, and the 90 degree PCV fitting.
