Results 1 to 3 of 3
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    Engine Oil Min Light on
    How many Qt i can add if the light on? I wasnt sure did i check the engine level correctly with the stick. Thanks
    B6 Noggy Avant, B8.5 Allroad
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 11 2010
    STL, MO
    Oil light comes one when you're 2 quarts low I believe, but I would always check the level before adding. You don't want to overfill it.
    Dec 03 2014
    SF/CA
    Quote Originally Posted by FulhamFTW View Post
    I thought it's 2Qt too, but I happened two times and it show ovefill (on the Dipstick) after i added 1.5qt or less, wonder any reason....
