Thought I'd post some quick thoughts on this interior lighting kit from deAuto Key. One disappointment with this car is the lighting is pretty soft and well, not much of a premium feel. When comparing the lighting to my brothers MK7 GTI, I'm still amazed in how much value that car delivers. Back on track here, deAuto Key's product is the fix.
Service & Support: To keep it simple, top notch as always. It's not so bold to say that deAuto Key is the go to for interior lighting.
Installation difficulty: If you have the right tools and an IQ equal or greater to a 5 year old, you're good to go. If you don't meet this, go see your doctor right away. A couple pix below.
Notice the labels. This eliminates any confusion.
I'll target the front dome light because this is where your brain encounters a test. Once the upper unit is dropped, in the center there's a round housing with the bulb. Simply twist and it pulls out. Here's where it gets "tricky", pull the OEM bulb from the round housing and input the new bulb, then twist back into place.
MISC. Notes: If you happen to blow a fuse. Stuff like this happens. You'll need a 7.5 amp and it's position 29 in the fuse box left of your steering wheel. Having tools for electronics can be helpful in popping out original bulbs. If you do want to retain original bulbs it might be worth keeping them free of natural hand oils or from your greasy pizza. If you put them back in, they can go pop.
Results: Crisp, clean and a more premium feel or look I should say. A cheap and easy must alteration. No sense in posting before pix. A couple pix of the overall look should be enough to help sway you if you're looking to do the same (vanity, trunk and glove box are all part of the kit). Now off to installing PSS10's with the KW delete kit- later MAG ride.
