Results 1 to 13 of 13
    Senior Member Three Rings S6Express's Avatar
    Jan 14 2014
    Miami, FL
    Coolant Temp High - Car Overheated
    Yesterday my 2013 S6 overheated. Coolant temperature reach 250 degrees. I stopped and turned it off. Looked under the hood and I could see the coolant boiling in the reservoir. 10 minutes later I re-stared and drove home. This morning the car asked for more coolant, I added about 2 cups. It may have a leak or something blocked the entrance to the radiator.
    Temps normal on the way to work this morning. Any clue?
    2013 S6
    Ibis White / Black Int / Innovation / Bang & Olufsen / LED Headlights / Carbon Inlays / Black Headliner / Sunshades / Cold Weather
    Mods:
    HRE P47SC 21" x 9.5" Wheels / RS7 Rear Diffuser & Oval Exhaust Tips / Red Bembos / Bigger Rear Spoiler / Dead Pedal S6 Badge / Black Wrapped Grille Slats / Black Wrapped Grille Edge / Black Window Trim / K&N Drop In / Escort Max360 Hardwired w/ Remote SmartCord / VAG COM Mods / 35% Tint
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    Stuck thermostat maybe?
    2015 Porsche 911 Turbo S
    Established Member Two Rings cooncified's Avatar
    Oct 16 2013
    Orange County
    Agreed, most likely the thermostat. Had the issue with my 3.0T and its pretty common, first 4.0T I have heard it happening to though.
    Oct 16 2014
    South FL
    Are you detecting any odor of escaping coolant? A few months ago I smelled coolant and discovered that one of the hoses that connects to the reservoir had split where it fits over the barbed end of the connector. It was leaking coolant onto the ABS unit, but there were no traces of a leak on the ground. I got the low coolant warning on the way to the dealer to get the hose replaced, but the car never overheated.
    Jan 14 2014
    Miami, FL
    Quote Originally Posted by ronbars View Post
    I did find a couple of ounces of coolant on my garage floor a couple of weeks ago. I monitored the floor ever since, but didn't see anymore, until yesterday's problem. It was missing a couple of cups, so there has to be some coolant coming out. I have an appt this afternoon.
    2013 S6
    Mods:
    Active Member Two Rings JayNana's Avatar
    Dec 21 2015
    London
    Thermos are usually designed to get stuck opened if at all, not closed aren't they?
    Leaking hose or radiator stone damage maybe?
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by S6Express View Post
    Audi is known for having coolant pump problems. Also, these motors run hot. Over time, coolant will burn and/or evaporate a little. If there is too little coolant, it will overheat. If you are at or near 30,000 miles, it might be time to change/flush the coolant. I was starting to smell coolant a short while ago. No leaks detected, but my coolant level was right below the MIN level in the tank. I actually sucked out about a quart of old coolant out of the reservoir, then refilled it with fresh coolant to the MAX. Problem solved. I may also try a product called Water Wetter by Redline which increases the heat carrying capacity of the coolant.
    It seems that right around 30-35k, these cars need a big time service......
    Oil change
    Air filter
    Coolant flush and change
    Spark plugs
    DSG fluid
    brake fluid & possibly pads/rotors
    Did I miss anything?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Thermostat was stuck open on the 2013 S6 I had on loan. Took forever to heat up and allow full revs. I've never heard of one stuck closed, but I guess it's possible.
    It's not good for these engines to overheat, especially bad for the turbos. I wonder if it has any error codes that might give you a clue as to what's happening.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Jan 14 2014
    Miami, FL
    Quote Originally Posted by MadAboutCars View Post
    Car is at the dealer. I'll post when I know what happened.
    2013 S6
    Mods:
    Jan 14 2014
    Miami, FL
    Dealer says they ordered new coolant pipe per TSB. Problem is...I already had the coolant pipe TSB 2036167/1 performed in Sept 2014.
    Is this a case of a dealer not really checking and just going by the TSB book?
    2013 S6
    Mods:
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    Kinda sounds like they aren't doing any investigating and throwing parts at it per the TSB. It's warranty work so that isn't surprising since it only pays so much. I would think that the service history would show the TSB previously completed though.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Aug 27 2015
    New Zealand
    They probably have a better pipe now, that will last a lot longer. Last time they probably just fitted the same one.
    Jan 14 2014
    Miami, FL
    I was very vaguely told that it was a different TSB....No new TSB number or explanation given.
    2013 S6
    Mods:
