Page 1 of 3 123 LastLast
Results 1 to 40 of 83
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    B6 S4 Caliper Slide Pins
    Posting this here for those of you with rear B6/B7 S4 rear calipers...
    Where can I find rear caliper slide pins? I've purchased slide pins from both RockAuto and through Amazon. Both sets were much bigger than the slide pins that came with the S4 calipers even though fitment was listed for B6/B7 S4.
    Shown in the picture is a Raybestos P/N: H15244 next to the correct pin.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Feb 09 2013
    WNY
    seriously, no one?
    Jan 09 2012
    MA
    I do not see a p/n for just the pin but here is a kit
    https://www.ecstuning.com/Search/Sit...470A/ES450994/
    Apr 07 2011
    Maybe contact the dealer and see if they're sold separately? If they are hopefully the person on the phone would be so kind to give you a part number. If not just see how much they charge for them and see if it's worth paying for.
    Feb 09 2013
    WNY
    I just contacted the dealer and they say that only the whole carrier is available.
    Apr 07 2011
    Damn that sucks. Gotta be some option out there for what you need.
    Feb 09 2013
    WNY
    Exactly! I can't believe how difficult it is to find these damn things.
    I posted this in the S4 section and that hasn't been much help.
    Apr 07 2011
    Are yours damaged? Why not reuse them?
    Feb 09 2013
    WNY
    One of the slide pins was seized and as a result quite corroded. I cleaned it up with a die grinder and sanding wheel, so it's a little better now but the slider pin has quite a bit of slop in the carrier. The other three pins are perfectly fine and would reuse them.
    Feb 09 2013
    WNY
    Frustrated. Contacted a few different dealers and they all told me slide pins are not available separately.
    I even tried contacting Cardone, which rebuilds the calipers but the customer service rep said that they are not available and can not tell me where they get them.
    I contacted a TRW location here in the US about slide pins, so we will see what they say.
    Jan 09 2012
    MA
    What's wrong with the kit I posted a link to? It has the pins plus a couple rubber boots and bolts. According to the parts catalog that is the only way to get the pins (as part of that kit)
    Aug 26 2005
    Quote Originally Posted by deyrag View Post
    The kit you linked to does not include guide pins, it provides only guide pin boots, mounting bolts and guide pin lube, no guide pins.
    Vorsprung durch Technik
    Feb 09 2013
    WNY
    Yep. Exactly.
    I posted this same question in the B6/B7 S4 section and someone linked me to the same kit.
    Feb 09 2013
    WNY
    So I'm reaaaaaally digging deep here.
    Amazon lists Wagner H4805 as fitting a B6 S4. Looked up that part on Google and it pulled up this CarID page.
    Scrolling down to the full vehicle fitment list, a bunch of domestic cars/trucks like Dodge and Ford come up as well as a few Audi models like the C6 A6, D3 A8/S8 and B6/7 S4.
    So I look up the D3 A8 and S8 on ECS, and they offer the same incorrect TRW kit for the rear, ST1160KT.
    So now I do not really trust that fitment list.
    I also looked up the 2005 F250 super duty since that apparently uses the same guide pin... check it out
    Clicky Click
    They look like the same shape, but I have a strong feeling that they will be the same size as the ones in my original post.
    Jan 09 2012
    MA
    Quote Originally Posted by fR3ZNO View Post
    Yep. Exactly.
    It says it includes the pins in the description
    Feb 09 2013
    WNY
    I think that may be just a generic description. ECS is usually pretty good about showing everything in the pictures. Plus, the OEM part number on EKTA only shows bolts, boots and lube as well.
    Jun 27 2011
    Why not look up the kit on the parts manufacturers website. The people who manufacture the parts wouldn't be wrong.
    Centric makes a rebuild kit and they're an extremely trustworthy source:
    It includes slider pins. All the rebuild kits should include pins.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 09 2013
    WNY
    I actually purchased the repair kits the same time as the first set of slider pins from RockAuto. The centric kit is good, has all the seals you need (not just the piston seal and dust boot) but no slide pins.
    I did look on TRW's website for brake parts, but only pads came up. No slide pins.
    I emailed a TRW location here in the US, so we'll see what they say. It's weird that TRW provides slide pin kits for other calipers, like on the A4 and RS4 but not for the S4.
    Feb 09 2013
    WNY
    Jan 09 2012
    MA
    Jun 27 2011
    Aww shoot, really? Damn, sorry about that. I'm trying to remember what brand slider pins I bought a few years back for my b7a4 rears. I want to say it was raybestos or something...
    You absolutely CAN buy new sliders, I'm now really curious, haha. I've got some free time today so I'll do some sleuthing and post back when I find something.
    -CP
    2017 Q7 3.0t
    Feb 09 2013
    WNY
    Did it happen to be the Raybestos P/N mentioned in the OP?
    That is why I am looking so hard for these, it seems wasteful to buy a whole new carrier when I can just get the sliders. Someone definitely makes them, how else would companies be able to rebuild the carriers that come with the "loaded calipers"?
    Are B7 A4 rears the same as B6/B7 S4 rears?
    I saw that when I was looking on eBay earlier. That would be the final option for me if it comes down to it.
    Jun 27 2011
    The calipers are wider to accommodated the much thicker vented rotor, but that doesn't necessarily mean the sliders are different. The Pistons are larger though so that's why the seal kits are different.
    -CP
    2017 Q7 3.0t
    Feb 09 2013
    WNY
    Here's the other thread I posted in the S4 section
    Feb 09 2013
    WNY
    Ah. I forgot the B7 A4 is solid rotor.
    Depending on how much free time you have do you think you could pull a slide pin quick and take some measurements?
    Jun 27 2011
    Hah, I definitely can't do that, its raining and cold here in Seattle. I only have b7 a4 rears on my current car though, since its a b7 a4. I sold the b6 last year and it also only had b7 a4 rears.
    What about this kit?
    http://www.dormanproducts.com/p-7235...olt&origin=YMM
    -CP
    2017 Q7 3.0t
    Feb 09 2013
    WNY
    No worries! haha.
    That was the kit I bought from RockAuto! The slide pins were the same size as the ones shown in the OP. They're way too big.
    I just can't believe that no one with a B6 S4 or A4 with S4 rears has replaced the slide pins by themselves...
    Jun 27 2011
    Shit. You're absolutely sure you have s4 rears right, not a4 rears?
    If I have a minute later today I can check my basement for my old b7 a4 slider pins. I probably tossed them though because one was bent from mishandling during shipping...
    -CP
    2017 Q7 3.0t
    Feb 09 2013
    WNY
    Yep. The salvage place I bought them from assured me they were from a 2004 (B6) S4.
    They definitely look like this too:
    Jun 27 2011
    Can you measure the clearance in the carrier? It should be at least 22mm to clear the vented rotor.
    Also not sure if this helps, but its the b7 a4 and b7 s4 guide pin specs:
    Most of the specs aren't important, but the diameter specs could be helpful to compare tot he pins you have to see whats what.
    -CP
    2017 Q7 3.0t
    Jun 27 2011
    Also, curiously, most companies don't list guide bolts for the B6 S4... Wagner seems to be the only one as you mentioned earlier. I'm not sure why that is as I was under the impression they didn't change the rear brakes (or the front brakes, really) on the S4 between the b6 and b7 generations... Could be they used a slightly different caliper that just happens to fit the same rotors?
    -CP
    2017 Q7 3.0t
    Feb 09 2013
    WNY
    I'm not sure how the diameter of the slide pin can be 2.95" and 1.18".
    Jun 27 2011
    Maybe at different points? Yea I've got no clue but I figure one of those values would actually be relevant. Likely the smaller one.
    -CP
    2017 Q7 3.0t
    Feb 09 2013
    WNY
    But still, an inch is way off.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The information for the bolt lengths and bolt diameters got reversed.
    Feb 09 2013
    WNY
    I was curious about that as well, but the caliper and carrier part numbers for B6 and B7 are the same per ECS.
    Jan 09 2012
    MA
    For a 2005 (latest year i have info for)
    S4 (300 x 22 rotor) carrier p/n = 8E0615425B
    A4 (255 x 12 rotor) carrier p/n = 8E0615425A
    A4 (245 x 12 rotor) carrier p/n = 8E0615425
    None of them list guide pins as a separate p/n
    Feb 09 2013
    WNY
    Some of those Raybestos dimensions make no sense. Packaged weight is 0.31"? lolwut.
    I have the B7 S4 Raybestos slide pins here. I got them off Amazon. Listed as fitting a B7 S4 and I assumed that since B6 and B7 brakes are the same, they'd fit.
    So the 2.95" is the bolt length. But 1.18" is definitely not the diameter. Not sure what feature that dimension referred to.
    Just for reference, the slide pins from my B6 S4 carrier have an overall length of 2.612", a bolt head of 0.594", and pin diameter of 0.330"
    Feb 09 2013
    WNY
    You said length and diameter was reversed. 2.95" is clearly the length, but there is no feature that equals 1.18".
    Dec 28 2006
    Western Maryland
    Sorry. Not paying enough attention. Carry on.....
    I assumed the 1.18" was the second bolt in each set.
