I read the following below and still have Q's re: this. To get these adjustable control arms or not. They're very pricey as yall know ~$300 or so. I have some ST coils I am gonna install in spring. I dont want to burn thru a bunch of rubber though after I install.
Necessary in your opinion?
What are the specs to ZERO OUT to avoid this?
Even when zeroing out----does this always solve the problem or does it sometimes show up and sometime not?
The reason I suggested adjustable UCAs is because when I was 24.5" ftg I had 2 degrees of negative camber. Considering the front camber cannot be adjusted stock, such excessive negative camber can lead to excessive tire wear even if the toe and caster is all corrected.
